Activity Forums Adobe Premiere Pro Can’t access track audio keyframes
  • Can’t access track audio keyframes
    Posted by Tim Boknecht on October 16, 2014 at 3:05 pm
    I’ve done some automation on an audio track, but I can’t pull up the keyframes to adjust the automation manually. According to this, I should be able to select “Show Track Keyframes” from the Show Keyframes menu on the audio track as shown in this image:
    Instead, all I see is this:
    This is consternating, to say the least. Can someone explain to me how I can access this critical audio automation feature?
    Tim Boknecht
    Media Producer
    Bravo Productions
    Tim Boknecht replied 11 years, 11 months ago 1 Member · 1 Reply
  • Tim Boknecht
    October 16, 2014 at 3:27 pm
    Found the fix. Posting it here in case other editors experience the same issue and stumble across this post.
    To be able to see the track keyframes I had to enable the “Show FX Badges” found in the Timeline Display Settings (the wrench menu on the timeline):
    And now you can see my issue is resolved:
    Tim Boknecht
    Media Producer
    Bravo Productions
