Activity Forums VEGAS Pro Canopus ADVC-100 & Vegas 6
  • Canopus ADVC-100 & Vegas 6
    Posted by J-p Desrochers on November 11, 2005 at 6:15 pm
    Had anyone using a Canopus ADVC-100 experienced
    missing sound when clicking the ‘Capture’ option
    while in the preview window?
    The sound comes shortly then goes out.
    It then comes back while recording though.
    Any help welcomed.
    JP
    J-p Desrochers replied 20 years, 10 months ago 3 Members · 3 Replies
  • Rich Stahle
    November 12, 2005 at 2:32 am
    I ad an ADVC-50 – one model below – had all kinds of problems which turned out to be a bad firewire cable in the end. After replacing it worked like a charm!
    Double check all your connections and cables!
    UVTV Productions
    Damaged Goods
  • Jeremy Rochefort
    November 12, 2005 at 11:16 am
    How are you capturing? The ADVC has an “analog” or “digital” switch”.
    This more often than not plays a role!
    Cheers
    Jeremy
    http://www.mjproductions.co.za
    MJ Productions
    Never let the need for money outweigh the need for Quality, Friendly & Proffessional Service
  • J-p Desrochers
    November 14, 2005 at 1:19 pm
    I’m capturing the analog signal from my Satelite receiver’s SVHS output.
    The audio is the analog right/left outputs.
    By the way I don’t think it’s my firewire cable that causes
    my sound or video to stop when opening the capture window since
    when I record everything goes well with no dropouts at all.
    My signal break are there only when the capture window
    comes up then they stays the way they are until I start recording.
    This is annoying since I’d be glad to here and see the
    satelite channel before starting recording.
