Activity Forums Canon Cameras CanonPro/prosumer camera you can use as a web cam
  • CanonPro/prosumer camera you can use as a web cam
    Posted by Michael Mohr on November 20, 2012 at 9:06 pm
    I’m trying to find a tapeless camera that I can also use as a web camera. I liked how the tape based cameras had a firewire output where you could do this. I used it for live streaming. Are any of the tapelss cameras able to do this? (under $2K) They have USB but no IEEE1394 outputs and I am told the USB is only for file transfer.
    Roger Van duyn replied 13 years, 10 months ago 2 Members · 1 Reply
  • Roger Van duyn
    November 21, 2012 at 8:21 pm
    As far as I know, only tape based cameras have a firewire jack. Like you said, the USB ports are only for file transfer.
    If you still have a tape based camera, you don’t need to have a tape in your tape camera for it to stream. On my Canon XH-A1, and A1S under the
    SYSTEM SETUP menu, chose the DV CONTROL option.
    Basically, it’s the same as setting up recording to a FireStore or other external recording device through firewire. I also use this setting to record to a laptop.
    I’ve had other cameras, such as an old Sony
    Digital 8, with firewire output that you don’t need to even set anything to set anything.
    If you no longer have a tape based camera with a firewire port, pawn shops and flea markets have tons of used ones. Also garage sales. For what you want to do, the tape mechanism doesn’t even have to work.
    Roger
