Activity › Forums › Canon Cameras › Canon XL2 – Sony PD170 – FCP – Compatibility
  • Canon XL2 – Sony PD170 – FCP – Compatibility
    Posted by Eleventwelve on November 28, 2006 at 9:18 pm
    I have some concerns and need advice regarding any issues of compatibility between FCP, Sony PD170 Camera, and Canon XL2 Camera.
    Briefly, the set-up is as follows;
    – I am editing a project I shot on a Sony PD170 in DVCam mode. 4:3 aspect ratio.
    – I also use the PD170 as a feeder deck for firewire capture in FCP.
    – I am arranging for supplementary footage to be shot by another videographer. She owns, and would like to use, a Canon XL2 Camcorder for the shoot.
    The question is…..what instruction can I give the videographer for camera settings on the XL2 that will ensure the DV footage she delivers will; A) be compatible with the rest of the edit in terms of format in my existing FCP project (described above) and B) will playback for capture from the PD170 that I am feeding with.
    The Canon XL2 has variable frame rate settings as well as both 4:3 and 16:9 aspect ratio. It can shoot at 24p, 30p, or 60i. I have not determined whether or not it can shoot in DVCam mode. I am assuming that if she sets her camera to shoot at 60i and 4:3 that her DV tapes should work for me. Am I wrong here? I need some solid advice before she shoots.
    Thanks everyone.
    – G5 dual 2.5
    – OS X – 10.3.5
    – 2.5 GB Ram
    – QuickTime Player 6.5.1
    – Final Cut Pro HD 4.5
    Don Greening replied 19 years, 10 months ago 2 Members · 1 Reply
  • Don Greening
    November 28, 2006 at 9:45 pm
    [eleventwelve] ” I am assuming that if she sets her camera to shoot at 60i and 4:3 that her DV tapes should work for me. Am I wrong here? I need some solid advice before she shoots.”
    I combine footage from my PD170, GL2 and XL2 all the time. You got it right. Tell her 60i in 4:3 with her XL2. There is no setting on the XL2 for recording in DV Cam mode.
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
