Activity Forums Apple Final Cut Pro Legacy canon xl1s & final cut pro 7.0.3
  • canon xl1s & final cut pro 7.0.3
    Posted by Gary Graham on October 9, 2013 at 4:54 pm
    can someone please help
    im trying to log and capture video from my canon xl1s mini dv into final cut pro 7.0.3
    i have the firewire800 – 9pin male to 4 pin male connected to the canon & my imac
    yet FCP wont recognise the camera and imovie wont or quicktime ?
    when i check apple website for compatability with canon xl1s it says its a firewire camera compatible with FCP
    (Canon XL1S PAL Easy Setup:DV-PAL FireWire Basic)
    https://support.apple.com/kb/HT4887
    is there anything im doing wrong or need to download etc for FCP to recognise the camera.
    thanks.
    Gary Graham replied 12 years, 11 months ago 2 Members · 8 Replies
  • 8 Replies
  • Bill Dewald
    October 9, 2013 at 10:30 pm
    I remember FCP being super picky when it came to talking to Canon cameras via firewire.
    Do what Dave said about your prefs, and also look at the firewire side of it:
    * Make sure your cable is properly functioning – they can be fragile
    * Make sure you are using a separate FW bus for the capture – no other FW devices (including drives) should be on the same bus.
    * Have your camera connected and in VTR mode before you launch FCP. I believe the XL1s displays a “DV IN” icon in the viewfinder when it’s communicating through the FW port.
    Good luck!
  • Gary Graham
    October 14, 2013 at 10:09 pm
    thanks trying that shortly the firewire 800 cable im using is new from maplin store 2 days ago.
  • Gary Graham
    October 15, 2013 at 6:04 pm
    downloaded that app and trashed preferences with the app.
    final cut pro wont recognise the camera imovie wont & quicktime trying new recording only recognises built in isight to my imac.
    i cant get any programme to recognise the camera canon xl1s which is in VCR mode playing the recording through the camera yet no programme/software can find the camera to import the media.
    the Nikkai firewire 800 (IEEE1394b) cable which is 9pin male to 4 pin male was only purchased from maplin store a few days ago by myself.
    is it possible the cable is faulty or is the problem with the software.
    ps i tried my camera on a friends imac same problem using same firewire cable and also tried a sony hdv camera & still FCP imovie quicktime etc wouldn’t recognise any of the cameras.
    so far i have tried – FCP7 – FCPX10 – final cut express – imovie – quicktime none have recognised the camera.
    i can connect my camera using (elgato video capture) software which is via Red white audio cables & yellow video cable but the quality is terrible,it makes the video into a 700mb mp4 straight from original tape recording.
  • Gary Graham
    October 15, 2013 at 6:08 pm
    when im connected via firewire 800 playing in vcr mode i dont see the info you mentioned above ( I believe the XL1s displays a “DV IN” icon in the viewfinder when it’s communicating through the FW port.)
    i’m stumped regarding is it a software problem or a faulty firewire cable 3 days old.
  • Gary Graham
    October 15, 2013 at 6:12 pm
    i’m also connected to mains supply while playing vcr through firewire i had also seen that suggested to connect camera to mains instead of battery power.
    just putting as much info as possible on as i can to eliminate what i’ve already tried.
  • Gary Graham
    October 15, 2013 at 6:14 pm
    apple list of supported cameras including canon xl1s
  • Bill Dewald
    October 15, 2013 at 6:15 pm
    It’s quite possible that you’ve got a bad firewire cable. They are pretty fragile, and the four-pin variety is pretty rare at this point.
    Since you’ve tested a variety of applications and devices, the common thread is the cable. Try exchanging it.
    Also, are there any other devices on your firewire bus? Take a look at About This Mac > More Info > Hardware > Firewire. The idea is that the camera should be the only device on the firewire bus.
    Good luck!
  • Gary Graham
    October 15, 2013 at 6:24 pm
    the system profiler isn’t showing the camera via firewire. see image below
    https://img36.imageshack.us/img36/7263/nq98.jpg
