Activity › Forums › Canon Cameras › Canon XL-H1 – does it output embedded audio from HD-SDI BNC ?
Posted by Bob Zelin on June 16, 2006 at 9:20 pmHi –
does the Canon XL-H1 embed the audio into the HD-SDI stream when playing back
from the HDV VTR ?Bob Zelin
(and can anyone answer my previous question on the Canon Console CCU program ?).
Miles Johnston replied 17 years, 8 months ago 5 Members · 4 Replies -
Daniel E
June 17, 2006 at 2:18 pmUnfortunately the Canon HDSDI does not include either audio or TC. You have to access these seperately. As for the Console question I suggest you ask Canon directly. I haven’t tried it out since I run stuff on a Mac.
Daniel Epstein
Gold Teleproductions, Inc
New York, NY
http://www.goldtele.com -
Randall Raymond
June 23, 2006 at 2:59 pmYou will need to get the Miranda doo-hickey thingie to embed audio and timecode in the HD-SDI signal out. You have to do the same thing with XDCAM HD when going HD-SDI out.
Donald Berube
August 10, 2006 at 5:15 amI prefer the Convergent design HD-Connect LE box. I have one and it is very robust and works like a charm.
Gives any HDV camcorder an SDI output with embedded audio. Gives you RS-422 deck control too with embedded timecode too. Just like my AJA Kona 2 card likes it.
I’m using this box all the time for one thing or another…
Can also use it to cross convert HDV 1080i footage to HD-SDI 720 60P – I have done this and it is cool.https://www.convergent-design.com/CD_Products_HDConnectLE.htm
– don
https://noisybrain.com
https://www.bosfcpug.org
https://fcpugnetwork.org -
Miles Johnston
December 7, 2008 at 8:03 pmHow can you access the audio separately, when as soon as the HD/SD SDI connector is plugged in, all audio connectors are mute. Except the heaphone jack.
Could not believe that its not possible to playback recorded tape from this deck, using SDI. What is the point of it, if you cannot access the audio!Fiannly used the YUV via an Extreme. A MAJOR disappointment with this camera, Useless specs and useless sockets. This is not made clear in the manual.
It should say When using SDI, All audio output is shut down, thereby making any use of the SDI worthless.
