Activity Forums Apple Final Cut Pro Legacy Canon XHA1 and Final cut 5.0.4
  • Canon XHA1 and Final cut 5.0.4
    Posted by Raul De la garza on August 17, 2011 at 10:59 pm
    Hi.Somebody can help me.
    I’m trying to capture HD footage from Canon XH A1 to final cut 5.0.4. but I can’t find the right configuration.
    I don’t know what is the right selection for:
    SEQUENCE PRESET,
    CAPTURE PRESET and
    DEVICE CONTROL PRESET?
    I have a G5 with MAC OS 10.5.8 with 3.5 G Memory
    Thanks Raul
    Raul De la garza replied 14 years, 8 months ago 4 Members · 6 Replies
  • Shane Ross
    August 17, 2011 at 11:20 pm
    Use the Easy Setups…choose HDV 1080i60 one and you should be good to go.
    Shane
  • Raul De la garza
    August 17, 2011 at 11:38 pm
    Thank’s Shane, but It doesn’t work… FCP crashes and abort… Some other ajustemnts in the system?
  • Michael Gissing
    August 18, 2011 at 1:45 am
    I recall when I tried to capture from an XLH1 with old FCP software, I had to use DV firewire basic for control. I then used SDI input for the video, so I was only using the camera set to downconvert to DV for machine control.
    Canon cameras were a problem with that version of FCP. If you have shot in standard 60i then you can capture from a Sony Z1 which is the only reliable HDV camera that worked in Vers5.0
  • Raul De la garza
    August 18, 2011 at 3:11 am
    Thanks Michael… So what version of FC recomend taht works with XH A1?
  • David Foster
    August 18, 2011 at 5:57 pm
    The biggest help I can give is make sure you don’t have any other FireWire devices hooked up when the Canon is connected. Canons don’t like to share FireWire with anything. Capturing to esata or internal drive, or USB will work
  • Raul De la garza
    August 18, 2011 at 6:06 pm
    Thank’s David… But there’s no another device connected…
    Do you know if FINAL CUT EXPRESS 4 works fine, with my system?
