Activity Forums Apple Final Cut Pro Legacy Canon XH-A1 HD footage works but audio is way delayed!
  • Canon XH-A1 HD footage works but audio is way delayed!
    Posted by Danny Thompson on June 14, 2009 at 4:07 am
    Hey guys, I know a lot of people complain on here about how they cannot get their HD footage to properly import onto their computer. I am running final cut 5.1 on a macbook pro and am trying to get my new HD footage 1080i @24 fps onto my computer. I imported the entire 50 minute long tape and and instantly fell in love with my quality, but then i turned up my volume to find it to be WAY out of sync..when i am importing it says that the capture is delayed a specific percentage, do you think that could be whats causing it?
    Noah Crowe replied 16 years, 11 months ago 4 Members · 6 Replies
  • Bill Doyle
    June 14, 2009 at 2:30 pm
    Danny,
    There are a lot more qualified individuals here than I am, but a few thoughts. Assuming everything is in sync when you watch from the camera, how are you capturing? Converting to ProRes? Batch Capture? Capture Now?
    If you’re not doing a ProRes through FireWire conversion when capturing, there shouldn’t be a delay. Is there a sync issue when you just watch the clip in the viewer or only from the timeline? Have you confirmed your sequence setting are 23.98 (24p)?
    I’ve been capturing Canon’s 24f from an A1 into a MacBook Pro for years without a sync issue, so I know it can be solved.
    Bill
    17″ MBP (1st gen Intel 2.16 GHz) w/ 2 GB RAM running OS 10.5.6, FCP 6.0.5, QT 7.5.5, 23″ ACD, Matrox MXO, Canon XH-A1
  • Steve Eisen
    June 14, 2009 at 2:33 pm
    It is showing you a percentage delayed because FCP cannot show you realtime HDV capture. I assume you are hearing this when you capture (not import) your tape. This is normal.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Danny Thompson
    June 14, 2009 at 4:40 pm
    Bill,
    First off, thanks for the reply. Now I cant do the PRO RES because i am not using final cut 6. What do you have under your audio/video settings when you import your footage?
  • Danny Thompson
    June 14, 2009 at 10:31 pm
    See my problem isn’t the video, its strictly the audio. Not only is it out of sync, it also is changing positions each time from shot to shot, making it impossible to simply rematch the two.
  • Danny Thompson
    June 15, 2009 at 2:15 am
    anyone??
  • Noah Crowe
    September 29, 2009 at 12:16 am
    Danny,
    I have dealt with this issue before. While I was not shooting in HD, I was shooting on the XH-A1. I don’t think HD is the issue–it’s how Quicktime and FCP deal with 24f-(23.98). Is there audio sync slip just in FCP, but not when you open the captured file in Quicktime directly from your capture scratch on your hard drive?
    Or is the file out of sync in the viwer, the canvas, and in Quicktime proper?
    Check:
    Do not open FCP
    Open your movie file directly from your hard drive.
    It should open automatically in Quicktime.
    If this file plays back correctly, but it has audio sync slippage in FCP, then here is the work-around I have used:
    open file in QT
    export:options:settings
    settings:
    frame rate: custom 23.98
    compressor type: DvDVCPRO-ntsc
    scan mode: progressive
    aspect ratio: 16:9
    uncheck internet streaming
    quality at BEST
    Hope this serves you.
