Activity Forums Apple Final Cut Pro Legacy Canon XH A1 and final cut 6
  • Canon XH A1 and final cut 6
    Posted by Rick Dervisevic on August 24, 2007 at 10:49 pm
    OK, I’ve read everything I could possibly read on this subject, spoke to both Apple and Canon and I still am not capturing with full capacity and ease.
    Apple recommends the following capture settings for my cam:
    – HDV 1080/60i
    – HDV
    – “firewire basic” or “firewire” [tried both]
    Canon recommends:
    – ensure “Playback Standard” under “Signal Settings” is set to HDV, not Auto.
    – Nothing else which isnt completely obvious
    What happens when I try to capture?
    I can operate the tape remotely with the computer but as soon as I press Capture Now, Capture Clip or the other capture buttons, the computer gives me the following error message…
    “no date received from device” [or soemthing like that]
    Canon and Apple are pointing to the other for a solution so I’m hoping to get some help now from a true expert, a regular user with the same equipment.
    BTW, I’ve captured HDV just fine in the past with this camera using Sony Vegas
    Thank you all!
    Rick
    PS. I have this same post on the Canon Camcorder forum
    Joseph Puma replied 18 years, 3 months ago 7 Members · 15 Replies
  • 15 Replies
  • Catherine Ceigersmidt
    August 24, 2007 at 11:16 pm
    Hi Rick,
    I have a Canon XH-G1 and I’m also editing on FCP6…what frame rate is your video? If you’re shooting in 24F, use the “HDV 1080p24” preset. If it’s 60i, then it sounds like your settings are correct. Are you getting timecode in the Log/Capture window when you operate your camera remotely?
  • Chris Poisson
    August 25, 2007 at 11:56 am
    Rick,
    What Cathy says may help, although I was surprise that when I was testing capture with my A1, I put 30f, 24F and 60i in a row on one tape, and it captured each one at the proper frame rate on it’s own, on the fly. It knew!
    You seem to be doing everything right, as a last resort I would take a paper clip and push the reset button on top of the camera, but first, try trashing your FCP prefs, use an HDV easy setup when it re-boots, plug the FW cable into the camera BEFORE you launch FCP and see if that helps.
  • Rick Dervisevic
    August 25, 2007 at 4:10 pm
    Thanks, before I do the reset thing, I thought I would run this past you. Last night I was fiddling and while the tape was running, I pressed “Capture Now” and it worked! I captured the whole tape without a hitch. I cant imagine this is how its supposed to work? If I wanted to create in and out points, logically it seems to me, that wouldn’t work but maybe this is how its supposed to be???
  • Chris Poisson
    August 25, 2007 at 9:23 pm
    Oh, well, I have never done anything else but capture now. Just always shoot plenty of handles and you should get through most anything.
    August 26, 2007 at 12:17 pm
    From my experience, you’re better off using ‘Capture Now’ b/c the nature of the footage forces a new clip to be made every time there’s a timecode break. FCP gets a little weirded out when you mark and In and Out point beyond a break in video. The most efficient way is to capture the whole tape, then log the captured footage afterwards.
  • Chris Poisson
    August 26, 2007 at 8:37 pm
    I agree with Cathy, as long as you name your clips and store them properly, you should be good to go.
  • Jan Bliddal
    August 27, 2007 at 12:26 pm
    Hi CathyCam just to be sure that I understand you right.
    When capturing in hdv from the XH A1 you will use capture now instead of log and capture and then use log and capture later to rename the captured files? If understood correctly why?
    The reason for my asking is that I recieved my Canon XH A1 on friday. I am not going to capture any HDV material to Final Cut 6 anytime soon, but I would like to be prepared when I need to.
    Thanks in advanced
    Let the machine work for you. Not you for the machine
    August 27, 2007 at 12:35 pm
    Hi Jan,
    Yes, exactly. To be honest I don’t really know what the true cause of the clip splitting is. Below might be a clearer explanation of what happens (another editor who first brought this issue to my attention, and I have since confirmed that he was correct):
    “The only really annoying thing I found with taking the HDV over firewire… Any time there was a camera stop, even if there was no timecode break, FCP forced a new clip on capture. So after logging a few tapes and then setting up some batch captures I got back all these split up partial clips. I tried re-logging paying stricter attention to camera stops – but sometimes on a static shot it’s pretty hard to tell, especially when the tape is running by in FF. Eventually I gave up and captured full tapes, letting FCP choose the in/outs based on camera stops; I logged after the captures and deleted the garbage.”
    Hope it’s helpful!
    ~ Cathy
  • Alvaro Lanciai
    December 11, 2007 at 4:46 pm
    hi there…
    I’ve experienced the same prbs with the same equipments….
    it seems to be incredible but I solved everything just changing the fire wire input from the front to the back…connecting my cable in the firewire connection on tha backside of my mac…everything was working correctly…..
    and ‘i’m not the only one ….
    MAC INTEL dual quadcore 3ghz
    4gb ram
    macos 10.4.11
    fcp 6.0.1
  • Dirk Ramon durchgraf
    January 10, 2008 at 11:24 pm
    Hello there.
    I just bought a Canon XH A1. I have managed to capture HDV, but cannot seem to be able to switch “External Video” to “All Frames” so as to be able to view the sequence on an external reference monitor.
    Also he HDV option is not selectable in the Video Playback Menu. Any idea what might help ?
