Activity Forums Canon Cameras Canon XF305 initialise card problem
  • Canon XF305 initialise card problem
    Posted by Stephen Rangott on April 17, 2012 at 1:54 am
    Hi Everyone,
    I consider myself quite proficient with the EX1/3 cameras and tapeless system but we just received two Canon XF305’s at my work and I’ve encountered an issue with one of them.
    So when I put a CF card in slot A it tells me to initialise which is to be expected coming from a Z7P. However it keeps failing each time I try. If I put the card in slot B it initialises fine and from there on works perfectly. I have tried several different cards and brands. The pins are all straight, I’m hoping its not a hardware issues since its brand new. Only been tested once.
    Any suggestions on what to try? As I said if it was an Ex1 I would have a better idea what to do but I’m not familiar with canons at all.
    Thanks everyone!
    Stephen Rangott replied 14 years, 4 months ago 2 Members · 2 Replies
  • Khalifa Al said
    April 28, 2012 at 10:56 pm
    I am experiencing a similar problem as Stephen Rangott.
    When I put my card in Slot A, it tells me CF A error but the same card works absolutely fine in Slot B.
    Does anyone know what I should do to fix this?
    Thanks.
  • Stephen Rangott
    April 30, 2012 at 5:23 am
    Hey Khalifa,
    Well I figured it out. Upon closer inspection one of the pins is bent very slightly. Even with 2 other people looking we all missed it the first time. I had a lot of trouble spotting it but it was definitely a bent pin problem. its working now.
    I feel quite sheepish but at least its working.
    Cheers,
    Steve
