Activity Forums Canon Cameras Canon XF300 Sky Detail Issue
  • Marc Franklin
    April 18, 2025 at 2:54 pm
    Hi Kacey,
    The XF300 Is a pretty old camera, about 15 years old. I would suggest that you go in to the set up menu and see if the previous owner played with the camera’s image. Some owners tweak the color matrix and how it reacts for certain scenes. I believe there are some youtube videos about this.
    Marc
  • Kacey Larsen
    April 18, 2025 at 3:22 pm
    I checked, and since I had factory reset it, the custom picture settings were off. Is there anything else that this could be caused by? I can take some pictures of what the camera’s switches are set to if that’ll be helpful.
    And I’m aware that it’s old! I wanted a digital version of the camera I had used for 13 years in order to have parity with my older footage 🙂 Works well for documentaries that I’ve been capturing footage for for over a decade.
  • Marc Franklin
    April 18, 2025 at 3:33 pm
    If you want to post the pics, I’ll look. I never used that camera though. I have used the XF405, XF705, XF605, XC10, XA15, XA40, and XA50, but they were all from a different generation of cameras. I believe your XF300 is MPEG-2 based files, and the ones I use are MP4, using different color science and compression.
  • Kacey Larsen
    April 18, 2025 at 3:39 pm
  • Marc Franklin
    April 18, 2025 at 4:44 pm
    You have the gain set to whatever you have “M” set for. Gain can do funny things to the picture, if you don’t need it. What is your white balance for “A” set to?
