Activity › Forums › VEGAS Pro › Canon Xf100-xf300 .mxf file stitching
  • Canon Xf100-xf300 .mxf file stitching
    Posted by A.miller@yourmusicmuse.com Mueller on April 3, 2012 at 7:07 pm
    There are a couple of abandoned posts about this topic and no one has been clear on how to get this done. To be clear: Most cameras cut video files into 2gb chunks. If you record something continuously for 20-30 minutes you will end up with multiple 2gb files for that time instead of one complete file.
    Most AVCHD cameras that I have used will either come with a program to stitch the files together properly or Vegas does it via its device explorer.
    I just got the canon xf100 camera and it uses .mxf files. Does anyone here use that camera and have you found a way to stitch together the files?
    The reason some of us want to do this is because a: It just makes sense and b: it makes applying complex fx groupings way easier and c: if you do any multicam shooting when you combine the tracks it puts cuts where those events end. Again I could get used to this but I just want to see if I can do things like how I have been before I give up.
    Lee
    https://www.yourmusicmuse.com
  • 0 Replies
