Canon XF100 Shutter Speed Advice
Hi fellow cows.
I recently purchased an xf100 camcorder and noticed a small issue.
I`ve always used 1/50 shutter with my xl1s 25fps standard def camcorder and had great results but using the same shutter with the xf100 HD 50i (25fps) i always get motion blur and this is at walking speed nothing faster.
Set the xf100 to 1/100 shutter and it is fine.
Is this normal as I always thought 25fps 1/50 shutter is correct but the xf100 requires 1/100.
Any advice would be much appreciated
