Activity Forums Apple Final Cut Pro Legacy Canon XF100 shots not all viable in FCP 7
  • Canon XF100 shots not all viable in FCP 7
    Posted by Tommy Brown on November 6, 2012 at 9:58 am
    Hi there.
    Was wondering if any of you might have come across this issue. We work on two shows where I am based (there are about 10 editors) with three full time cameramen. All three shoot on Canon cameras (1 XF100 & 2 XF300’s). When we use the FCP 7 plugin not all the shots appear from time to time and are missed but if viewed in the Canon XF Utility they are there. 90% of the time however no one has time to duplicate the footage using the Canon XF Utility program and then transcoding to Prores 422.
    Do any of you know how I can check what version of the plugin I have for FCP 7 or know of the issue why some shots are missing?
    All the editors use FCP 7 on Lion and Snow Leopard with different levels of Apple updates (mine is fully updated Lion) and we still have the issue. I cut on iMac and on a Macbook Pro.
    Your help will be appreciated, thanks.
    Michael Gissing replied 13 years, 10 months ago 2 Members · 1 Reply
  • Michael Gissing
    November 6, 2012 at 9:11 pm
    My experience of Log & Transfer is that you have to leave the computer alone when ingesting. Even though it appears to work as a background process, changing to another screen, starting to edit, checking emails or having a browser open increases the chance that a clip may only partial convert.
    So I make sure no other software is open, setup the L&T batch and walk away. Afterwards I check that all shots are in and correct duration.
