Activity › Forums › Apple Final Cut Pro › Canon XF import utility
  • Canon XF import utility
    Posted by Michael Sanders on February 16, 2012 at 5:54 pm
    In case anyone hasn’t noticed: Canon released their utility to import XF and C300 files into FCP X.
    Download it, install it. Open up import from camera with a Card in the reader and off you go..
    Except one big caveat (and I’m fairly sure I haven’t missed anything): It ignores recorded clip names and numbers and renames all the clips by date and time…. which is useless if you have done a two camera shoot and made a point of making sure each camera had its clip naming set right.
    Oh and FCP X seems to do a batch name wrongly as well 🙁 I thought OH well I’ll just use the batch name to rename all the clips but for some reason, despite FCP being set to sort by TC it renamed them in a strange way.
    Luckily there’s only 15 clips on each camera…
    Michael Sanders
    London Based DP/Editor
    David Battistella replied 14 years, 7 months ago 2 Members · 2 Replies
  • Michael Sanders
    February 16, 2012 at 5:58 pm
    Update: If you use FCP X to rename to original camera name, its does what it should do and restores the clips names. But why rename it in the first place?
    Michael Sanders
  • David Battistella
    February 17, 2012 at 9:57 am
    It’s probably a keyword thing Michael.
    That’s all I can assume at this point!
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://vimeo.com/battistella
