Activity › Forums › Apple Final Cut Pro Legacy › Canon Vixia import, FCP 6?
  • Canon Vixia import, FCP 6?
    Posted by Kyle Rebar on August 25, 2012 at 2:31 pm
    Hey guys,
    We’re testing out a Vixia HGF10 at work, but its video files (.mts, some mpeg variant, I think) aren’t native to our macs. Is there anyway to import these files into FCP 6, or convert them to a workable format? We’ve tried using Compressor and Episode with no luck…
    Any input is greatly appreciated…
    Shane Ross replied 14 years, 1 month ago 3 Members · 3 Replies
  • Ryan Holmes
    August 25, 2012 at 3:36 pm
    You’ll need to convert them to .mov so FCP can see them. I believe MPEG Streamclip (free) can handle the job for you.
    https://www.squared5.com
    I would convert them to a ProRes based codec. Since you’re using FCP6 I think you have access to ProRes422 (I would also recommend ProRes (LT), but I don’t think that was available until FCP7).
    Ryan Holmes
    http://www.ryanholmes.me
    vimeo.com/ryanholmes
  • Kyle Rebar
    August 25, 2012 at 5:29 pm
    Hm… Negative on the mpegstream clip, I get an error reading “Cannot read frame size” on export…
    However, I found a work around using iMovie, which can eat the .MTS files and spit out .MOVs. Strange that FCP can’t do this, but iMovie can.
    Thanks for the advice!
  • Shane Ross
    August 25, 2012 at 5:48 pm
    .MTS…then try ClipWrap2. It works with AVCHD files.
    Convert to ProRes
    Shane
    Little Frog Post
