Activity Forums Canon Cameras Canon Vixia HV30 AV->DV settings not enabled
  • Canon Vixia HV30 AV->DV settings not enabled
    Posted by Sam Cucher on August 18, 2009 at 4:58 pm
    I bought recently a Canon Vixia HV30 and am trying to capture footage to Final Cut Pro 5.0.4
    I am using the easy set up for 1080i60 and FCP allows me to control the camera in the Log and Capture window but I cannot see the video image. I can see the time code running, and after testing a “capture now” I got a black clip with audio, so for some reason the camera is not sending out the proper video signal. I read in the manual that the AV->DV setting must be switched to OFF for playback, the problem is that when I try to access this setting in the camera it is not enabled – all I see in the screen in a dotted line —-
    Any suggestions about what to do? What am I missing?
    Sam Cucher replied 17 years, 1 month ago 3 Members · 4 Replies
  • User Requested post notices bouncing
    August 18, 2009 at 6:03 pm
    Hello Sam;
    You did not say what format you recorded in; my HV30 can record in 5 different formats (DV 4X3, DV 16X9, HDV, HD “24P” and HD “30P”). I think that any HD format is actually recorded on the tape as HDV, so you have to use one of those easy setups. The only format that I have put in FCP6 is HD 24P or 30P, but it is still HDV on the tape. See the Apple support paper on the subject, such as https://support.apple.com/kb/HT2410?viewlocale=en_US,
    or search the internet for topics like “HV30 to FCP.” That’s how I found the above thread, and it got my footage in. It plays jerky on my G5 during pans, but it plays, and it is HD.
    Hope this helps.
    Terry
  • Sam Cucher
    August 18, 2009 at 6:36 pm
    Thank you Terry.
    I think that the problem is with the VCR function of the camera and not with the settings in FCP.
    I recorded mostly in HD24p, but as you say, I can use an easy set up for that.
    I am puzzled why the AV to DV setting is not accessible in the camera.
    I’ve done extensive searches on this and haven’t run into anybody else with a similar problem.
    Will keep trying.
    Sam
  • William Busby
    August 22, 2009 at 4:49 am
    I don’t have a definitive answer for you, but the av/dv bit shouldn’t have anything to do with capture unless you’re using the HV30 as a transcode device (running audio & video from another source via composite into the HV30, for example) into the HV30 to transcode to a dv signal. In other words, if you’re capturing via firewire, that setting shouldn’t make any difference.
  • Sam Cucher
    August 22, 2009 at 11:53 am
    Thanks for your advice. I figured out that much. I’m upgrading my system to a newer version of FCP and I hope that these problems will be resolved.
