Activity › Forums › DSLR Video › Canon T2i Playback
  • Canon T2i Playback
    Posted by Gerry Condez on May 24, 2010 at 5:46 pm
    Just want to know the playback through HDMI. Is the playback continuos or it play each separate clips each time? Just got a Letus but video are very dark even with 50mm f1.8 lens. Thanks
    Jonathan Ziegler replied 16 years, 4 months ago 2 Members · 3 Replies
  • Jonathan Ziegler
    May 24, 2010 at 7:59 pm
    You play each clip one at a time – click the “play” button, go to the clip you want, then hit Set, choose your play option(s), then hit set again to select play or whatever.
    Jonathan Ziegler
    https://www.electrictiger.com/
    520-360-8293
  • Gerry Condez
    May 24, 2010 at 9:51 pm
    Hi Jonathan, Please clarify the procedure, I dont have that camera yet. Once you hit SET, and choose play option, are there options to play back the entire video from start to end? Or, just the clip you selected, or both. Thanks again.
  • Jonathan Ziegler
    May 24, 2010 at 11:40 pm
    Again, just the clip you’ve selected. As far as I know, there’s no way to play back multiple clips continuously. This is all in the T2i manual – download here: https://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=139&modelid=19943 – if you don’t have the camera yet, the info won’t do you any good. 🙁
    Jonathan Ziegler
    520-360-8293
