Activity Forums Adobe Premiere Pro Canon MXF Workflow with Premiere CC, PluralEyes 3 & Speedgrade
  • Canon MXF Workflow with Premiere CC, PluralEyes 3 & Speedgrade
    Posted by Chris Mathews on June 24, 2013 at 9:24 pm
    Hi guys! I need some advice/tips.
    I shot a live stage performance with a Canon XF105 and 2-5DMKII’s. The XF105 shoots MXF files which are causing me problems.
    1. Imports just fine into Premiere CC but will not import natively into PluralEyes 3. I tried Red Giant’s workaround, but it still won’t import. Maybe I am doing something wrong.
    2. I can use the new Premiere CC Multi-Cam Sync to Audio, but I can bring the MXF files over to Speedgrade for grading.
    The more I work with the MXF files the more I don’t want to work with them. Should I just transcode to ProRes or something else to make this 2 hour performance easier to edit? If so, should I just use Adobe Media Encoder?
    Any and all advice with working with this format using the above software would be greatly appreciated.
    Chris Mathews replied 13 years, 1 month ago 2 Members · 2 Replies
