Activity Forums Canon Cameras Canon HV40 NTSC vs PAL.
  • Canon HV40 NTSC vs PAL.
    Posted by John Davies on April 25, 2010 at 3:15 am
    I am looking at buying an NTSC HV40 which will mainly be used in a PAL region. I’ve found a few other posts online about the issues encountered in this situation but thought it might be worth asking for a more specific guide…
    My videos will really only be for online distribution, with Premiere and After Effects work beforehand. What issues am I likely to run into using an NTSC format, and what would the benefits/disadvantages be of using this HV40 in a PAL region?
    Many thanks,
    Bob Dix replied 16 years, 4 months ago 2 Members · 2 Replies
  • Bob Dix
    April 27, 2010 at 11:57 pm
    We have been using a HV20 which is nearly identical with the HV40( the Hv40 runs at 30fps not 25 fps as in PAL. You will need to convert the clips , as many moving objects could look jerky) It can present an editing problem , if you intend to run it to a Tv Monitor in say Australia.(This can present a smooth running problem if not done correctly)The high definition clips from this videocamera are truly stunning on a Sony 1920 x 1080 i TV
    We were running a Canon 5D mark II at 30 fps and to do this was a nuisance, it has now been fixed by Canon’s Firmware Update 2.0.4.
    You should talk to Canon Technical Service ?
    Freelance Imaging & Video
    AUSTRALIA
  • Bob Dix
    April 28, 2010 at 12:01 am
    On line distribution should not cause an issue .Clips from a Canon 5D mark II @30 fps looks perfectly normal on the web.
    AUSTRALIA
