Activity › Forums › Apple Final Cut Pro Legacy › Canon HV30 to FCP to DVDSP…how?!?
  • Canon HV30 to FCP to DVDSP…how?!?
    Posted by Rafael on December 21, 2009 at 3:00 am
    I have been trying to find posting on forums or any website explaining a simple work flow. I read that it is possible to burn HD content onto a simple DVD with a max of 30 min.
    I have shot footage with my NTSC Canon HV30 and done my edit in FCP 7. it is about 29 minutes (less than 30 minutes in order to fit on a regular DVD.
    1) Then I used JES utility to reverse telecine to 24fps. Replace the footgae in FCP, rebuild the edit.
    2) Using Compressor, I tried different setting to get HD 23.976fps 1440×1080.
    3) Then I import in DVDSP the file, make a simple DVD one track, simple still background menu.
    4) I try to build the DVD with the HD content. It burns fine. But when I try to play it to my PSP3, it says “no valid datas”
    Does anyone know a website showing a simple work flow?! I spent the last 4 days trying to.
    Harry Powell replied 16 years, 9 months ago 5 Members · 6 Replies
  • Michael Gissing
    December 21, 2009 at 3:59 am
    DVD’s need standard definition mpeg files. In Compressor you will find presets for DVDs which produce m2v files for DVD Studios Pro.
    If you are attempting to make a High Def disk you will need to make a compatible file, either as mpeg2 or mpeg4 HD spec files. You can also make an SD DVD at 29.97 without reverse telecine.
    You seem to be going about this in a very complicated way without a basic understanding of the DVD format requirements. I suggest you read the DVD SP manual to see what the format requires.
  • Gary Milligan
    December 21, 2009 at 8:23 am
    I use Roxio Toast Titanium – as far as I know, that is the only Mac software currently available for simple authoring/burning of Blu-ray discs. I’m assuming you’re referring to Blu-ray – HD-DVD is a dead format. Toast does allow burning short high-def video onto standard DVDs, but I’m not sure if you can use a regular burner to do that or if you have to use a Blu-ray capable burner, which you would certainly need for longer videos (as well as Blu-ray discs of course). The HD disc function in DVDSP is a dead-end. PSP3 plays my “Toasted” Blu-ray discs no problem.
    Gary
    This is me – this is what I do – https://web.mac.com/garymmw
  • Bill Celnick
    December 21, 2009 at 11:30 am
    As was mentioned, you can’t do what you’re trying to do without a Blu-Ray burner, and you cannot author it in DVDSP.
    You can use Toast – I also have Adobe Premiere CS4 / Encore on my Mac, which also burns Blu-Ray.
    Simply put, you need to follow the whole process of encoding for Blu-Ray, then you need to burn to a conventional DVD with a Blu-Ray burner – and you will need a Blu-Ray dvd player to play your finished product, even though its on standard media.
    It does work, but you must realize that you are creating Blu-Ray, not DVD.
  • Harry Powell
    December 21, 2009 at 3:06 pm
    Haven’t tried it myself but according to this article, you can burn high definition video onto standard DVD-R discs (using the mac’s super-drive) that playback in a Blu-ray player (such as PS3).
    https://www.kenstone.net/fcp_homepage/burn_br_mac_superdrive_stone.html
    Let us know how you get on as I may need to do something similar in the future
  • Rafael
    December 21, 2009 at 5:32 pm
    Thank you for this link, it answers my problem.
    I also realized that DVDSP can’t author Blu-ray, which is really surprising. I tried to keep working with Final Cut Pro Studio, but I think Apple is getting behind. I’ll give a try with Encore CS4, which I never used until now.
  • Harry Powell
    December 21, 2009 at 6:46 pm
    [Rafael Macho] “Thank you for this link, it answers my problem.
    I also realized that DVDSP can’t author Blu-ray, which is really surprising. I tried to keep working with Final Cut Pro Studio, but I think Apple is getting behind. I’ll give a try with Encore CS4, which I never used until now.”
    Glad it was helpful, but curious about your conclusion? The link explains how to do it with FCP7 so why do you need to use Encore CS4?
