Activity › Forums › Adobe Premiere Pro › Canon HV20 and Premiere Pro CS3
  • Canon HV20 and Premiere Pro CS3
    Posted by Adam Martignetti on January 10, 2008 at 3:21 am
    Hi all. OK. Here’s my problem:
    I recorded something (A friend’s concert thing) at 1080i, 24p, cine mode, all that jazz. Filled two MiniDV tapes full of it. First of all, I realize that yes, they weren’t HDV tapes, but I didn’t have any, and I went ahead and recorded on MiniDV tapes using those settings anways (foolish, I know, but I’m still not exactly sure why). I go to capture it to Adobe Premiere Pro CS3, and I can CONTROL the camera from Premiere, but I cannot CAPTURE anything. I can play it using the controller in CS3, but it just plays on the camera, and nothing on the screen. Can anybody tell me what’s going on? How can I get Premiere to figure this out?
    Also, the Premiere project is at 24 fps, too.
    Perry Cheng replied 18 years, 8 months ago 2 Members · 3 Replies
  • Perry Cheng
    January 15, 2008 at 1:11 pm
    Martig,
    First, you don’t need HDV tape, MiniDV records just fine. You can not capture, probably because you have it set to a DV device. However, generally, you would not use PPro to capture HDV, unless you have a special card. You won’t be able to preview. I use HDVSplit instead. I still can not figure out, or perhaps it just does not, do true 24p even though your project might say so, it really does not.
    Perry
  • Adam Martignetti
    January 15, 2008 at 11:03 pm
    Hey Perry. Thanks for the advice. I tried a couple other sites, and they all pointed to HDVSplit. It works like a charm! Now I’m just having trouble exporting my work in widescreen format. I’ve got it all set to 16:9 and the original resolution and all that, but it still comes out looking like 4:3, so that kind of stinks. Hopefully I’ll find a way around that.
  • Perry Cheng
    January 15, 2008 at 11:23 pm
    Marting,
    Where are you viewing your final product? Do you have it set to view at 16×9? Download Mediainfo program to see what media format you have it set to export.
    Perry
