Activity › Forums › Canon Cameras › Canon HF100 30p (or not really?)
  • Canon HF100 30p (or not really?)
    Posted by Scott Norton on November 14, 2008 at 3:00 pm
    I have recently purchased an HF100, and have imported footage into FCP 6.0.4
    Although I have chosen the 30p setting on the camera while shooting, when I first attempt to place clips in the timeline, it prompts me saying it is switching the sequence setting to the “correct” settings – which are HDTV 1080i.
    If I look at the info of the capture, it says 29.97 for frame rate.
    Can anyone tell me if the 30p is simply a ‘trick’ for the look of 30p (and not really progressive), and whether I should still be editing at the suggested 1080i?
    Do I have to mess with pulling/dropping frames?
    Also, should I export choosing deinterlace?
    Or am I doing something wrong in the import section of the process???
    I have Toast which will convert using other Codecs – woudl that make more sense??
    Thanks in advance.
    Elijah Lynn replied 17 years, 10 months ago 2 Members · 1 Reply
  • Elijah Lynn
    November 26, 2008 at 6:38 am
    It is in a interlaced wrapper.
    Unless you are doing 24P, which I know very little about, you should just record 30P and set the sequence to the 1080i. You will still get the goodness of progressive!
