Activity › Forums › VEGAS Pro › Canon HF10 Rendering problems
  • Canon HF10 Rendering problems
    Posted by Joe Balsamo on July 25, 2008 at 1:02 pm
    Hello all,
    I’m new to the forum, hope you guys can help me out.
    Hope this is OK here in the Vegas Basics section. It seems like a pretty basic thing to me, at least!
    I’m having some issues when rendering my footage shot from a Canon HF10. I specifically mention the camera because I was using a Panasonic HDC-SD9 and having ZERO problems. I’m now using a aCanon HF10 and having a devil of a time.
    Basically, what’s happening is that no matter what I set my project to or my render to, I’m getting issues in the rendered files when I play them in WMP. I can play the raw MTS files in WMP and the footage is fine, so it’s NOT the HF10. As soon as I take the footage into Vegas and render it, then play in WMP, I’m getting all sorts of artifacting, studdering, some studdering sound, etc.
    This footage is all shot at 1920×1080 at 60i. I’m setting up my project using the default: HD 1080-60i (1920×1080, 29.970 fps)
    For render, I’ve rendered in just about everything you can imagine, just to try and get the darned thing to play smoothly! So far, I’m either getting really “studdery” video with a lot of visual noise, or a smooth video and weird audio playback.
    Any suggestions? I can provide a sample of this problem if anyone is interested. I’m really getting frustrated as this is TOTALLY sapping my productivity. I’m beginning to regret my decision of going with the HF10 over the SD9! I like the HF10 better, but with the SD9, my productivity was much better.
    Thoughts?
    Joe
    Andrey Baranovsky replied 18 years, 1 month ago 2 Members · 2 Replies
  • Joe Balsamo
    July 26, 2008 at 4:24 pm
    I think I may have solved my own issue here.
    I had installed a “test” DLL that allowed me to read-in and edit Panasonic HDC-SD9 files. Unfortunately, this “broke” the proper rendering of the Canon HF10 files. Things are much better since I switched back to the original DLL (remember if you make ANY changes in your system, set it up to restore back to the original!)
    In any case, this issue is solved for the time being.
    Joe
  • Andrey Baranovsky
    August 11, 2008 at 7:37 am
    I am too starting to work with HF100, and sony vegas pro 8a.
    I can do the editing fine, but my question concerns rendering.
    I want to be able to render into exactly the same format that my camera shoots in,
    so that the rendering of UNMODIFIED footage will be just a direct file copy….
    (and really fast as such).
    How do i do that?
    Andrey.
