Activity Forums Canon Cameras Canon FS21 video capture software with Mac OS
  • Canon FS21 video capture software with Mac OS
    Posted by Lisa Mangini on August 25, 2009 at 2:15 am
    I have a Canon FS21 Video Camera. The supplied software to import still images is compatible with Mac OS. However the software for importing video, is only Windows compatible.
    The camera is recording in 16:9, and iMovie will import the footage, but when the footage is then imported into a Final Cut Express sequence that is set to Pal Anamorphic it is squished into a 4:3 format.
    When looking at the properties of the footage that has been imported via iMovie, it says it is 720 x 576 footage, although in iMovie the project and footage are viewing as a widescreen image.
    1. is there some other way if importing footage from the camera with mac compatible software for the Canon FS21?
    2. Is there a way of fixing the footage imported by iMovie, then brought into Final Cut, that is squished into a 4:3 format?
    Lisa Mangini replied 17 years, 1 month ago 2 Members · 2 Replies
  • Leonie Jennings
    August 25, 2009 at 10:19 am
    Hi – I have been thinking of buying this same camcorder and have a MAC. I will be interested to know if resolved. Camera shop guy indicated needed imovie 09 – which i have. Are you using 08 or 09? Cheers
  • Lisa Mangini
    August 27, 2009 at 2:01 am
    I have imovie 09 and that imports the footage from the camera. Haven’t got a fix on squishy footage yet re: Final Cut. Will post if and when I do 🙂
