Activity Forums Canon DSLR Cameras Canon Eos plug in
  • Canon Eos plug in
    Posted by Suzin Daly on August 13, 2013 at 3:14 pm
    I am trying to bring in footage from Canon Rebel T4i. I downloaded the plug-in from Canon, link I was given Mark II, I downloaded from the Mark III. It looks to be the same. I was under the impression once the plug-in was down loaded and installed I would be able to log and transfer. However the log and transfer does not find the footage. What am I missing?
    Suzin Daly replied 13 years, 1 month ago 3 Members · 6 Replies
  • Warren Eig
    August 13, 2013 at 4:32 pm
    Try 5DtoRGB free from the App Store or the paid batch version which allows you to set up a render queue so you don’t have to sit and do one at a time. Much better results and multi-processor aware so it is much faster.
    Warren Eig
    O 310-470-0905
    email: warren@babyboompictures.com
    website: https://www.babyboompictures.com
    REEL: https://www.babyboompictures.com/BabyBoomPictures/Reels.html
  • Suzin Daly
    August 13, 2013 at 5:54 pm
    Warren,
    Thank you for the information. When I checked I would have to upgrade to 10.7 or more. Right now on am on 10.6 For now I am using a work around with MPEG Stream. It works well enough.
    Best
    Sz
  • Ryan Holmes
    August 15, 2013 at 2:00 pm
    Suzin – You have to keep the CF card structure intact when you transfer it over to your hard drive. So you can’t just grab the .MOV files and expect FCP L&T to see them. You have to bring the whole card over with its various folders and files.
    But again a program like MPEG Streamclip or 5DtoRGB will just grab the .MOV files and convert them to whatever you specify.
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
  • Suzin Daly
    August 16, 2013 at 2:06 pm
    Ryan,
    Thank you again pointing out about the ‘CF card structure intact’ .
    That I do understand and have kept it intact.
    Knowing people who have used the Canon Plug in and having it worked made me a bit of a pit bull in wanting it to work for me too. It seems it is a problem for the t4i, and others have had to modify the .plist… I am not going there.
    As you had suggested about other third party such as MPEG… that is what I am using. For now it works great and all I am doing is simple test shots etc. If in the future I get heavy into the Canon…. then I will research and look into other recommendations you have already mentioned.
    On another note, I again thank you for your response and taking the time to give guidance. It is truly very much appreciated.
    Best
    Sz
  • Ryan Holmes
    August 16, 2013 at 2:15 pm
    [Suzin Daly] “On another note, I again thank you for your response and taking the time to give guidance. It is truly very much appreciated. “
    No problem. Glad to help.
    You may look into getting out of the Canon consumer DSLR world – t3i, t4i, etc. If you move up into their “professional” bodies I don’t think you’d have these problems….at least in my experience I haven’t had them. I use a Canon 7D and 5D Mark III. But there’s also the 6D (and maybe the 60/70D would work better). Just something to consider if you want to go further down this road….
    Ryan Holmes
    @CutColorPost
  • Suzin Daly
    August 16, 2013 at 5:42 pm
    Ryan,
    Once again I thank you for taking the time to offer further information. I would definitely take your recommendations into consideration if I decide to move up to a new DSLR.
    Best
    Suz
