Activity Forums Canon Cameras Canon EOS 5DMKII for video use only?
  • Canon EOS 5DMKII for video use only?
    Posted by Janne Laiho on May 30, 2010 at 3:59 pm
    Hello,
    I’m considering purchasing a video camera. I have little knowledge of video in general, and I’m a bit confused as to what separates models from each other.
    I’ve checked out some stuff on Vimeo, and to me it seems – very surprisingly – that the most impressive footage by far is very often shot with a Canon EOS 5DMKII. I’m surprised because this is supposed to be a still camera with video capability.
    I’m now considering getting one for video use only. I’d like to know whether you professionals think this is a good or bad idea, and why. I will not shoot serious still photography. I work with After Effecs CS4 and FCP, I produce motion graphics and the occasional video (which is why I need a camera) for web delivery – I don’t envisage producing for TV/DVD any time soon. I will need to have a set-up that can be operated by me alone, i.e. little/no additional lights etc. (this is another reason I’m interested in the 5DMKII, it seems to deliver impressive results even in very dark lighting conditions). Sound is not a factor here, as I will be recording that separately.
    Any insight and advice would be greatly appreciated.
    Cheers,
    Janne
    Norman Willis replied 16 years, 3 months ago 4 Members · 3 Replies
  • Micah Mcdowell
    June 1, 2010 at 4:02 pm
    There’s tons and tons and TONS of information about these cameras and comparisons to other cameras in past threads here on the COW; you may want to go to the “DSLR Video” forum here and search around for a while to get a feel for what they are.
    Based on your brief description of what you need in a camera, it sounds like a 5DmkII might be perfect. Here’s a quick rundown of the current pros and cons:
    Pros:
    Excellent full 1080p HD video quality
    Impressive low-light performance
    Huge selection of interchangeable lenses
    Small size
    Controllable depth-of-field to get a very filmic narrow focus look
    Pro-quality stills
    Affordable
    Cons:
    Lousy audio capability (though the 5DmkII at least has manual levels now)
    Rolling shutter artifacts(read up on it; never has been an issue for me as long as I use a tripod)
    Aliasing (could be a problem depending on what you shoot)
    Video codecs (usually need to be transcoded before editing, not ideal)
    Ergonomics (lousy form factor for hand-held video, though you can buy shoulder-mount rigs to fix this)
  • Chas Smith
    June 2, 2010 at 4:51 pm
    Seems to me the “judder issue” isn’t that big of a deal unless you do a lot of “shaky-cam” or “swish-pan-zoom” for intentional effect. If you do slow tracking and/or slow panning… I don’t see it really happening all that much.
    As for audio recording… given that the camera would be used in place of a “film / motion picture camera” where there would be double-system audio recording anyway… it’s not that big of a dealbreaker. With these high-quality images at a lower-than-Red price… ponying up a little for separate audio recording shouldn’t be to big a deal, unless one-man-band is what you’re aiming for.
    My2cents
  • Norman Willis
    June 14, 2010 at 1:29 am
    I’m pretty much a ‘one man band’, and separate audio isn’t an issue at all. I just got one of those clapper boards to synch audio; and in a pinch, of course one can always clap the hands, although the spike is not quite as clean/sharp.
    Norman Willis
    http://www.nazareneisrael.org
