Canon DSLR Workflow
I have a few questions about the Canon DSLR workflow for Final Cut Pro 7.
1) When backing up the cards, would you recommend using any software to do so (as opposed to just copying over in the finder)? I heard that it may be better to do it that way, because some programs have a verification process that ensures that all the files have transferred over.
2) I know that FCP hates H.264 and that I should transcode the footage to ProRes. Is there any benefit to ingesting the footage as ProRes422 into FCP via Log and Transfer versus placing those videos directly into Compressor (without FCP)?
3) If the final product is going to be for the web, is it ok to go from H.264 to ProRes422 to H.264? Meaning: I transcoded the original H.264 footage into ProRes422 and will then transcode to H.264. Will the video have noticeable loss in image quality? Is it better to go through the online/offline process utilizing Media Manager? This leads me to my next question:
4) The client has also asked that I prepare the files for future use in festivals. I’m assuming that all festivals and screenings have different specifications needed for the video. I was thinking that I could give her the Full-Res version, so that she can transcode it to whatever she needs later. However, when I try to use the online/offline process to export out the video as a self-contained Quicktime, the video is jittery. What is the correct way to go about doing this?
Thank you!
