Activity › Forums › DSLR Video › Canon DSLR recorded a random DAT file amongst the MOV’s
Joel Bellagamba replied 1 year, 8 months ago 17 Members · 25 Replies
Claudinia Roman
January 30, 2019 at 2:54 pmThis happened to me on my Canon XA35. The power was not shut off or battaries changed when filming. It done it to the last MP4 file that was recorded. I had it recording in 30 min increments. I didn’t notice until i pulled it in post that the last file was a .DAT file but it showed it was almost a 4G file so i knew it had to be the last half of my recording. Fortunately i still had it on the sd card. I put it back in the camera it was recorded and corrupted on. I opened the card review section and it showed a ? mark on the corrupted file i double touched it and it showed a recovery option i selected recover and it took a few minutes but it did fix the errors and turned it into the MP4 file it was originally recorded at. I feel very lucky. Before i thought about putting it back in the camera i tried a couple of the free converter software suggested and they did not work. Hope this helps someone.
Stephen McFadden
December 6, 2020 at 12:46 amYes, Morton you’re a lifesaver. I just used aeroquartet.com. Fantastic service. My audio was off a bit when I get the file back but that’s easy fix. Well worth what I paid.
Sky Simone
February 18, 2021 at 12:01 amthe Grauonline.de site works, I tried the sample and am pleased.
I only need one video repaired but have to pay for 5 which is annoying but $35 is way cheaper than the high dollars the other people are quoting
Angel Andres rosado
February 18, 2021 at 12:43 amRight on!
At least you found a solution. This is probably the longest running thread on CreativeCow at this point.
Thanks for the feedback.
-Angel
