Activity Forums Canon Cameras Canon C300 MkII and external monitor via HDMI
  • Canon C300 MkII and external monitor via HDMI
    Posted by Nels Mclaughlin on April 18, 2019 at 5:11 pm
    Hey everyone –
    I have a new (purchased in December 2018) Canon C300 Mark II cinema camera, and I am trying to connect it to an external monitor – in this case, a Vizio TV AND a SmallHD monitor. I have a few setups that I’d like to use, but I cannot get the camera’s feed to show on the Vizio without also attaching the SmallHD and an HDMI splitter. Here’s the deal.
    I can successfully view on the SmallHD and the Vizio TV – both connected via HDMI thru the aforementioned splitter (1 in, 2 out). I can also successfully get a camera feed on the SmallHD when I connect it directly to the camera without the use of the splitter. However, I cannot for the life of me get the camera feed to show up on the Vizio by itself. The TV will only work if I have the SmallHD and the splitter attached and turned on. If I have the splitter in and powered on, but only the TV plugged in to one of the two outputs, it doesn’t work.
    I’ve tried different camera settings, different HDMI cables in all of the TV inputs and nothing works going directly from the camera to the TV – it always requires the SmallHD and the splitter.
    Is there a setting in the camera that I’m missing? Is it a power/HDMI issue? Is it the TV/monitor? H.E.L.P.
    Blaise Douros replied 7 years, 2 months ago 2 Members · 3 Replies
  • Blaise Douros
    April 18, 2019 at 6:18 pm
    I’ve had issues getting HDMI signal from an FS7 into certain consumer monitors unless the camera’s system frequency is set to 29.97 (or multiples thereof, e.g. 59.94–basically anything but 23.976). If your camera’s system frequency is set to 23.976, it could be that your TV will only take a 59.94 signal, and your splitter box is doing a conversion.
  • Nels Mclaughlin
    April 20, 2019 at 2:07 pm
    I thought the same thing, so I checked and the camera frequency is set to 59.94. Maybe stupid question – the inputs on the TV say 60Hz. I know drop frame doesnt equal non-drop frame, but could this be the issue?
  • Blaise Douros
    April 22, 2019 at 5:40 pm
    Nah, 59.94 = 60hz for all practical purposes on consumer equipment. Interesting problem. I don’t have any other useful suggestions other than to maybe try other combinations of cameras with the TV, or the C300II with another monitor.
