Activity › Forums › Adobe After Effects › Canon c300 files fail in After Effects and Prelude.
  • Canon c300 files fail in After Effects and Prelude.
    Posted by Jon Lewis on November 20, 2012 at 8:28 pm
    Hello all,
    – I’m working on a 2.6ghz macbook pro retina with 16gb ram
    – CS6 prelude, premiere pro, and after effects
    – Canon c300 footage (MXF files)
    – files located on internal hard drive (512gb SSD) and on CF card itself.
    – I have updated premiere pro and after effects to most recent versions with no change in results.
    I had MXF files from c300 brought over to my internal drive. I was editing with those files in Premiere just fine. I decided I would try using dynamic link to bring a few clips into AE (replace with composition).
    Upon opening, AE substituted these MXF clips with placeholders (color bars) and when I tried importing the same MXF clips directly, AE said that the files were “damaged or unsupported”.
    I decided I would try using Adobe Prelude to transcode the MXF files directly from the CF card into MPEG2, proRes, etc. Each attempt at transcoding failed, with the event error : ” Source file might not be an valid video/audio file!”
    It seems that my cs6 does not like MXF files from the c300.. but I cannot find another person with this problem online, much less a solution. Any ideas?
    Nils Crompton replied 12 years, 10 months ago 6 Members · 6 Replies
  • Todd Kopriva
    November 20, 2012 at 9:14 pm
    If you submit a bug report and include your contact information and the offer to provide a sample clip that is causing the problem, we can look into this.
    bug-report form:
    https://adobe.ly/ReportBug
    After Effects team blog
  • Michelle Mizner
    February 11, 2013 at 6:55 pm
    Hi Jon, Were you ever able to figure this out? I am having the same issue.
    Michelle
  • Anthony Dean
    May 21, 2013 at 3:32 pm
    any fix for this? I’m in the same boat. Surely there are others too?
  • Todd Kopriva
    May 21, 2013 at 4:34 pm
    There are bug fixes for Canon XF files in the upcoming versions After Effects, Premiere Pro, and Prelude, which are dues for release on June 17th.
  • Craig Ricker
    September 2, 2013 at 7:05 am
    Adobe media encoder also fails to transcode groups of mxf files imported from prelude. It just crashes. This is on the latest CC.
    Mac Pro 2 x 2.4Ghz, 16GB RAM, GTX 660
  • Nils Crompton
    November 11, 2013 at 11:03 pm
    Same here latest CC as of 12-11-13 OSX 10.8.5, intermittent fails, i.e. different clip each crash. No way to pick up where left off….
    iMac i7 2012, 32GB
    OSX 10.8.4
    Blackmagic Cinema Camera
