Activity Forums DaVinci Resolve Canon C300 – AAF export Avid to Resolve – timecode issue
  • Canon C300 – AAF export Avid to Resolve – timecode issue
    Posted by Onno Varekamp on November 18, 2012 at 8:58 pm
    I’m having difficulty conforming from an AAF to resolve, with C300 footage. There are always some clips that resolve doesn’t find. It says the timecodes do not match. I’ve tried linking to the MXF files from avid ,to the original camera files and I’ve tried first importing all footage clips into the mediapool. It seems to go wrong with the longer clips, the C300 then makes a new files that ends with 02 instead of 01.
    Does anyone have workaround/solution for this problem? It’s such a hassle to manually edit all these clips afterwards.
    Maybe it’s just one more update away for it will work 😉
    Daniel Mccullum replied 13 years, 5 months ago 2 Members · 1 Reply
  • Daniel Mccullum
    March 20, 2013 at 10:52 pm
    I’m having this same issue with Premiere. Have you solved your issue (and if so how) or are you still having it?
