Activity Forums VEGAS Pro Canon C200 Cinema RAW Lite Clips – PC Users
  • Canon C200 Cinema RAW Lite Clips – PC Users
    Posted by Neblackshirts on October 13, 2017 at 5:44 pm
    For those that have a Canon C200 and recorded RAW, has anyone had success importing the .dpx file sequence in VP14 or VP 15 that the Canon Cinema Raw Development software converts the raw files to? I tried for the first time last night and after three different conversion attempts (conversion from the Canon RAW files from the camera to the DPX RGB 10-bit file type) and neither version of Vegas said it would not a valid image sequence file type. I’m on a PC so I don’t have the option to convert to Apple ProRes 4444. I hate to have to use Resolve just to convert my clips to use in Vegas when I’ve read Vegas should be able to handle .dpx image sequences. Thanks!
    Tom Gomez replied 8 years, 2 months ago 5 Members · 18 Replies
  • 18 Replies
  • Aaron Star
    October 14, 2017 at 5:03 pm
    I would post a few files in a gdrive or dropbox share and see if others in the forum can help you figure this out.
    Is there an option to convert from RAW to EXR, or 16-bit BMP?
    I only have VP13 and am able to process .dpx files as an imported image sequence from an F35.
    Here is the media info on the 2 different formats of my files.
    Format : DPX
    Format version : Version 2.0
    File size : 11.9 MiB
    Format : DPX
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Color space : RGB
    Bit depth : 16 bits
    Compression mode : Lossless
    Stream size : 11.9 MiB (100%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Frame rate : 24.000
    And these from a film scan.
    Format : DPX
    Format version : Version 1.0
    File size : 190 MiB
    Writing library : TCS Scan V1.0
    Video
    Format : DPX
    Color space : RGB
    Bit depth : 10 bits
    Scan type : Progressive
    Stream size : 190 MiB (100%)
    Transfer characteristics : Printing density
  • Terry Hogan
    October 17, 2017 at 6:30 am
    Here is a Canon C200 Cinema RAW Light file if anyone wants to try to see what can be done with it. https://tbf.me/a/cPz6X
    Canon’s Cinema RAW Development Software is needed to make actual RAW adjustments to the file which is here: https://www.canon-europe.com/support/consumer_products/products/digital_cinema/digital_cinema_camera/eos_c200.aspx?type=download&language=EN&os=all
    I also have a Windows 10 computer so I can’t get the Canon software to render out a ProRes version of the adjusted RAW file and I have only been able to get Resolve not Vegas Pro to read the file. It does seem like a MAC computer will be necessary to render a ProRes version. On Windows computer, the Canon RAW Development software can’t render ProRes and the file formats it does render I have not been able to get Vegas Pro 14 to recognize. Canon has an Avid plugin that allows AVID to edit the Canon RAW Lite files. I hope the Vegas development team are looking into getting a Canon RAW Lite plugin from Canon that will work with Vegas Pro.
    Resolve can open the Canon Cinema RAW Lite file but it can’t yet make actual RAW adjustments so if your exposure and white balance are perfect then you can edit your RAW file in Resolve or render the file for us Windows user to a DNxHD file that can be edited in Vegas Pro. However, this workflow loses all the advantages of a RAW file and you need the full version of Resolve 14 to render the 4K Canon RAW Lite file to its full 4096×2160 resolution. The free Resolve version only renders to a UHD resolution with black bars.
  • Neblackshirts
    October 17, 2017 at 12:56 pm
    Thanks Terry for the upload. At least you’re experiencing the same issues I am as a Windows user. I wish Windows had a ProRes plugin that would allow export to the ProRes 4444 format. I am currently using the “Resolve to color correct—>render to UHD file–>Vegas to edit” workflow when I shoot RAW but as you said, it’s too bad this removes alot of the advantages of the RAW file. The final image does look better compared to the 4K MP4 (albeit the 4K MP4 still looks amazing), but with the workflow time and the sheer size of the RAW files and the fact that the workflow loses most of the advantages of the actual RAW file, I shoot mainly 4K MP4 now until (and hopefully) Vegas creates the plugin that will allow the Canon RAW .CRM files to work directly in Vegas. If Resolve can currently read them, there’s no reason all other high end NLE’s shouldn’t be able to as well. At the minimum, I hope Resolve creates the ability to fully edit the Canon RAW file prior to rendering to a format Vegas can open.
  • Marco Baer
    October 17, 2017 at 1:46 pm
    Can’t you offer a download of a few DPX frames instead? That would be only some MB and would have been quickly tested.
    DPX sequence import into Vegas Pro usually works fine here so far.
  • Terry Hogan
    October 17, 2017 at 8:10 pm
    https://tbf.me/a/1U1FQ Here are a couple of DPX files with separate WAV files that have to be manually synced to the video files.
  • Marco Baer
    October 17, 2017 at 9:27 pm
    Mmh, while other types of DPX files work fine for me in Vegas Pro, these certain ones do not work. Don’t know why.
    The only difference I see is the DPX files I usually work with don’t have any framerate information, but these Canon ones are said to be -0.000 fps (according to MediaInfo). Maybe there is something in the header which makes Vegas Pro to refuse them.
  • Neblackshirts
    October 17, 2017 at 9:55 pm
    Thanks Terry for posting the DPX files. Yep, Vegas can’t handle the new DPX render from the Canon Cinema Raw Development software. That is really the only option if you’re a PC user. Frustrating!
  • Terry Hogan
    October 18, 2017 at 10:21 pm
    I spoke with Canon’s 1-855-CINE-EOS (1-855-246-3367) technical support. The representative told me that I was the first one to complain about the C200’s RAW file and problems on a Windows PC. She said that she believed that Premiere can now process the DPX files and assemble them with audio WAV files back into complete clips. She also said if I had a MAC computer the Cinema RAW Development program could output a ProRes 444 clip. She had never heard of Vegas Pro. I asked that she submit a request to the Canon development team that they program Canon Cinema RAW Development to output a DNxHR 444 for Windows (since they output a ProRes file for MAC) and that they add to the firmware update coming out in February the ability for the C200 to record an XF AVC 10 bit 422 file internally for those of us who don’t want to deal with the current RAW file problems. I know DaVinci Resolve can output DNxHR on a Windows computer so Canon should be able to as well. Maybe if others message Canon and Vegas Pro development teams they will do something for us.
  • Marco Baer
    October 19, 2017 at 9:00 am
    “I asked that she submit a request to the Canon development team that they program Canon Cinema RAW Development to output a DNxHR 444 for Windows”
    Bear in mind Vegas Pro would need a MOV wrapper for this kind of video. It does not read MXF wrapped DNxHD/HR.
  • Neblackshirts
    October 19, 2017 at 1:40 pm
    Thanks Terry. I’ll contact Canon as well and put in the request, however, just like Macro said, this is as much of a Magix issue as it is a Canon issue. If Premiere and Resolve can handle the export formats from the Canon software (Resolve handles the native .CRW files!), there is NO reason why Vegas Pro shouldn’t either. Regarding the .DPX file sequence from the Canon software, there obviously is something different with these that Vegas can’t recognize. I’m not techie enough to figure it out but that is obviously more of a Canon issue than a Magix issue…but again, Premiere can read them, Vegas can’t. My guess is that Davinci will open up all of the RAW processing in Resolve for the .CRW that they have for Blackmagic RAW video files (not that the Canon software offers much in terms of RAW file editing!) before Canon or Magix do anything about the issue.
