Activity › Forums › Apple Final Cut Pro › Canon C100 PF30 clips in FCPX
  • Canon C100 PF30 clips in FCPX
    Posted by Olof Ekbergh on November 28, 2012 at 1:58 pm
    I just got the new C100. I love the camera, fantastic images.
    But just a word of caution if you shoot 1080 29.97 progressive (and 25 frame as well I think). Canon does not use the same version of AVCHD as Sony and others, it is 24mb/s but they dont tag the PSF files so that FCPX can interpret them as progressive.
    This will mess you up when you export, the solution is to either re wrap before import, using ClipWrap, or to change the field interpretation in the clip inspector. You can batch convert this by highlighting all the clips you just imported or one by one. The clips come in tagged 1080i.
    If you drop these clips into a manually set 30P project they should be interpreted as progressive, but the first time I did this it did not work.
    This is just a heads up, it is easy to deal with.
    Here are some clips from the C100:
    https://vimeo.com/54304912
    Olof Ekbergh
    Dave Gage replied 13 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Oliver Peters
    November 28, 2012 at 2:41 pm
    [olof ekbergh] “Canon does not use the same version of AVCHD as Sony and others, it is 24mb/s but they dont tag the PSF files so that FCPX can interpret them as progressive.”
    Have you installed the Canon XF plug-in? If so, is that the normal case with the plug-in installed.
    The codec is not AVCHD. It is a 4:2:2 MPEG2 variant, just like XDCAM and the same as is used in Canon’s XF video cameras.
    Technically 1080PsF is interlaced 1080i, not Progressive in the sense of the type of signal it is. It’s only progressive at the imager. Although PsF can easily be treated as P, broadcast output cards and monitors actually see these as quite different signals. So 1080Psf=1080i.
    FWIW – it’s my understanding from Apple that there’s still work to be done by Canon on the plug-in/importer.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Oliver Peters
    November 28, 2012 at 2:44 pm
    [Oliver Peters] “The codec is not AVCHD. It is a 4:2:2 MPEG2 variant, just like XDCAM and the same as is used in Canon’s XF video cameras.”
    Oops. I’m wrong. I work with the C300 a lot and didn’t realize the C100 was using a different codec.
    – Oliver
    Orlando, FL
  • Paul Figgiani
    November 28, 2012 at 5:00 pm
    Olof,
    This is off topic – I have a question:
    In my clip Inspector/Info pane (Settings View) I don’t see a Timecode Display popup as displayed in your image. Am I missing something?
    thanks.
    -paul.
  • Olof Ekbergh
    November 28, 2012 at 8:49 pm
    THe upper right timecode is the duration of the clip. In FCPX 10.0.6 anyway.
    Olof Ekbergh
  • Paul Figgiani
    November 28, 2012 at 11:31 pm
    Olof,
    I’m referring to the Timecode Display popup menu …
    thx.
    -paul.
  • Olof Ekbergh
    November 29, 2012 at 1:33 am
    As far as I remember this has always been there.
    Is it possible your clips don’t have embedded TC?
    Olof Ekbergh
  • Dave Gage
    November 29, 2012 at 6:01 pm
    [olof ekbergh] “But just a word of caution if you shoot 1080 29.97 progressive (and 25 frame as well I think). Canon does not use the same version of AVCHD as Sony and others, it is 24mb/s but they dont tag the PSF files so that FCPX can interpret them as progressive.”
    Yes, I went through this about a year ago with my Canon S100-
    https://forums.creativecow.net/thread/344/6302
    I bought ClipWrap and have been using it ever since. It solves this problem and also allows me to pre-name my files, organize, and toss out the trash files before I edit. I still backup the original card and keep the file structure in tact, but I never use it. I also edit the files on my 2011 MBP i7 and external RAID 1 enclosure without optimizing and it works just fine.
    At some point, I will need to get a second camera which I’d prefer be very similar to my Canon S100 (I’m running out of learning curve time), so I will take a look at the C100.
    Dave
  • Dave Gage
    November 29, 2012 at 6:20 pm
    [Dave Gage] “At some point, I will need to get a second camera which I’d prefer be very similar to my Canon S100 (I’m running out of learning curve time), so I will take a look at the C100.”
    Okay, never mind. I just Googled the C100. That’s a big boy camera and way out of my price range. I’m in the $700- $1000 range for my needs. Very cool though.
    Dave
