Activity Forums AJA Video Systems Canon C100 HDMI>Ki-Pro
  • Canon C100 HDMI>Ki-Pro
    Posted by Dan Luke on December 13, 2012 at 12:15 am
    I have a ki-pro mini. They suggest when recording at 24p or pf24 you configure the HDMI port for 3:2 pulldown and use the VFR setting on the Ki-Pro. Only problem is, I can’t find any setting for the HDMI port other than rec command and timecode.
    Dan Luke replied 13 years, 9 months ago 1 Member · 1 Reply
  • Dan Luke
    December 13, 2012 at 11:29 pm
    Rudy from AJA support had the answer.
    Menu -> 00:00 -> User Bit -> Output Mode -> Set to Pulldown
    on the C100
