Activity › Forums › VEGAS Pro › Canon C-100 question
  • Canon C-100 question
    Posted by Kelly Griffin on September 26, 2019 at 5:54 pm
    I’m posting this here because I “know you guys” and assume that somebody’s gonna have a C-100 and will know what’s going on.
    I’ve noticed that if a fair amount of time goes by between firing up my camera, it appears to revert to factory settings; i.e., it asks for a date and time, my frame rates are different than what I set, audio settings different, etc.
    I’m suspecting something to do with the internal battery starting to go on me (?) If that’s the case, I assume those can be replaced, and, is that something I can do myself (?)
    –KG
    Ole Kristiansen replied 7 years ago 3 Members · 2 Replies
  • Mike Kujbida
    September 26, 2019 at 7:36 pm
    Kelly, a Google search says you’re right. It needs to back to Canon as it’s not a user replaceable item ☹
    I did find this which may or may not help.
    Good luck!
    Built-in Rechargeable Lithium Battery
    The camcorder has a built-in rechargeable lithium battery
    to keep the date/time and other settings. The built-in
    lithium battery is recharged while you use the camcorder; however, it will discharge completely if you do not use
    the camcorder for about 3 months.
    To recharge the built-in lithium battery:
    Connect the DC cable and compac
    t power adapter to the camcorder
    and use a household power outlet to power the cam
    corder for 24 hours while it is turned off.”
    This means that an authorized Canon service center will have to replace it. I don’t know of anyone who sells this battery or where you would get instructions on where it is and how to change it. You will need to send your camera to a country that has an authorized EOS Cinema camera repair center.
  • Ole Kristiansen
    September 27, 2019 at 7:09 am
    I had the same problem with my old Canon XF100 – end up with save all setting on a sd card and on start just reload the settings from the sd card !
