Activity › Forums › Adobe Premiere Pro › Canon 7D Sequence Settings
  • Canon 7D Sequence Settings
    Posted by Ashley Ripka on August 18, 2011 at 7:42 pm
    I film with a Canon 7D. When I open Premier I am prompted with the new sequence settings. I have tried everything to get my footage settings to match up with this. My footage is 1280 x 720 and I shoot at 60 fps. Can anybody help?
    I can never get the footage to match up to the viewer, the clip is either too big or too small.
    Jonas Bendsen replied 13 years, 7 months ago 3 Members · 4 Replies
  • Kevin Monahan
    August 18, 2011 at 8:23 pm
    When you see the New Sequence window, press cancel and move right into the application. Drag and drop a clip on to the New Item button at the bottom of the Project panel. Doing so will make a sequence that matches your footage precisely.
    Try it and report back.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Ashley Ripka
    August 18, 2011 at 8:44 pm
    Awesome!! It works! I’ve always used Final Cut, but I’m trying to gain knowledge in other editing programs.
    Thank you so much!
  • Kevin Monahan
    August 18, 2011 at 9:12 pm
    Great it works! And good for you learning more NLEs. That way, you can never turn down a job because you don’t know a system.
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • Jonas Bendsen
    March 3, 2013 at 6:45 pm
    Out of curiosity, what version did they implement this? Doesn’t seem to work in CS4 (I’ll be upgrading to CS6 this week).
    This is my life, I edit and edit and edit and edit…
