Activity › Forums › Canon DSLR Cameras › Canon 7D Partial Video Corruption
  • Canon 7D Partial Video Corruption
    Posted by Casey J porter on October 16, 2012 at 4:21 pm
    I’ve been shooting over 30 short introductions for a client to use for their media. This has happened twice so far and that is what ever is moving the most in frame, a locked off shot with someone talking, the face is corrupt for only about two seconds then it clears back up. But that corruption covered the whole face. I recently upgraded to the latest firmware and was wondering if that has anything to do with it? On another shoot I also filmed a car driving into frame and the same thing happened, corruption only over the moving car for about two seconds. All this happened after the upgrade.
    Any ideas?
    Thank You.
    Al Bergstein replied 13 years, 11 months ago 4 Members · 9 Replies
  • 9 Replies
  • Al Bergstein
    October 17, 2012 at 3:05 pm
    Have upgraded, no sign of corruption. What cards are you using?
    Al
  • Casey J porter
    October 18, 2012 at 12:17 am
    Promaster CF, two 8GB, two 16GB.
  • Al Bergstein
    October 18, 2012 at 12:31 am
    Professional or Performance?
    Also, if the cards are at fault, as I understand it, the Promasters have a lifetime warranty. Perhaps you should return one and see if it’s the card?
    I’ve read so many horror stories of card failures, and I have had bad luck with Lexmark for example, that I’ve found Sandisk Extreme Pro’s to be bullet proof, so I stay with them now. I’ve never experienced a card failure with them, and that was not true with Lexmark.
    Good luck.
    Al
  • Casey J porter
    October 18, 2012 at 2:04 am
    Awesome. Thank you very much. I’m going to contact Promaster and get with them.
  • Terence Kearns
    October 18, 2012 at 3:16 am
    And always roll tape with a backup camera. That’s what my 500D is for. flash cards aren’t really reliable enough for “mission critical” applications (like one-time only shoots).
  • Al Bergstein
    October 18, 2012 at 5:41 am
    I shoot plenty of ‘one time shoots’ with cards. I don’t worry about cards at all since Sandisk. I would never shoot a backup ‘a’ with tape, absurd. If i’m concerned, I step up to an xf105/305 with dual cf card slots, and mirroring.
    But i’m not saying that his problem might not be the camera. Start with the most likely failure point.
    Al
  • Terence Kearns
    October 18, 2012 at 7:52 am
    “roll tape” is a figure of speech. I thought that was obvious.
  • Ervin Tia
    October 18, 2012 at 11:25 pm
    I’m not sure if you’re doing it already, a card reformat ensures a clean slate (card), helps reduce glitches.
    I usually do it before any major shoot. Important to do it in the device (camera).
    Ervz | Check out some videos I helped produce.
    https://vimeo.com/ervzman/videos
  • Al Bergstein
    October 19, 2012 at 12:32 am
    That’s true, and something we didn’t ask about. If you aren’t doing that, that could be the root cause of your problems. We sort of assumed you weren’t doing that.
    Al
