Activity › Forums › Apple Final Cut Pro Legacy › Canon 7D issue
Michael Gissing
July 28, 2010 at 11:56 pmYou can’t just connect the canon cameras to the computer. They come with software which needs to be installed. Once you do that the camera will mount properly and you can see the CF card correctly from L&T.
Personally I prefer to use a Sandisk FW800 CF reader which is much faster to L&T files from the card, rather than connecting the camera and using USB speed.
Gon Perdigao
October 12, 2010 at 6:30 pmi had the same problem, cause i pass all the files to a hard drive.
But after some research in the web i found the solution to this problem!You only have to create the folders of the CF card and that is it.
See the link : https://blog.youdownwithfcp.com/2010/05/04/how-to-import-7d-video-from-your-hard-drive/
