Activity Forums Apple Final Cut Pro Legacy Canon 7D FCP Plug-in
  • Canon 7D FCP Plug-in
    Posted by Mike Albertini on August 23, 2011 at 4:54 pm
    Ive been given a ton of 7D footage to edit…but only in a folder which is a copy from the original card…it includes all the original folders though ie DCIM and MISC and files ie both .mov and.thm etc…
    In the tutorials I’ve watched on this, the original card from the camera is being used which has made me wonder whether i can use this plug-in with just this copied folder…
    In one tutorial I watched someone copy the footage from the original card, to a folder on the desktop, then make a disk image of the folder and used this duplicate disk image for fcp log and transfer…
    https://www.youtube.com/watch?v=1fqTxX1zamo
    If I create a disk image from the folder I have, do you think the Canon Plug-in will work with it ok?…Or will I have problems somewhere down the line as I’m not using the original camera card?
    Any advice would be much appreciated
    Mike
    Heather Slepchik replied 15 years ago 4 Members · 4 Replies
  • Steve Eisen
    August 23, 2011 at 5:46 pm
    Watch this tutorial:
    https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
    As long as you have kept the entire file structure intact, you are fine.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Everest Mokaeff
    August 23, 2011 at 6:25 pm
    The latest version of plugin lets you transcode 5D/7D thru L&T without any issues with only one folder containing .mov and .thm files. I do it all the time. No-brainer.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • Mike Albertini
    August 23, 2011 at 7:30 pm
    Hi Steve & Everest,
    Thanks for your answers…just wanted to double check before I started…Much appreciated
    Cheers,
    Mike
  • Heather Slepchik
    August 30, 2011 at 4:59 am
    I have located the plug-in on the Canon site, however it is an update – could you suggest where I can download the actual software?
