Activity › Forums › DSLR Video › Canon 600D frame rate settings
  • Canon 600D frame rate settings
    Posted by Isaac Anderson on June 4, 2014 at 11:19 am
    Can I change the frame rate of a canon 600D to about 10?
    I need it for a project, that I could do with pictures, but video at a low frame rate would be the best. If I need to use Magic lantern or similar, that’s fine.
    I
    Email: starstreamvideo@gmail.com
    Paul Stancel replied 12 years, 3 months ago 2 Members · 1 Reply
  • Paul Stancel
    June 14, 2014 at 9:29 am
    Yes, i believe you will need magic lantern for that, i think that the lowest framerate on the 600d is 24 fps, in magic lantern you can go down to like 1 fps, there is a great tutorial on youtube on how to install magic lantern
