Activity Forums DSLR Video Canon 5D: weird brightness flicker
  • Canon 5D: weird brightness flicker
    Posted by Andy Taplin on December 1, 2010 at 6:03 pm
    Hi All
    I shot an interview with the 5D and there is a random brightness/gamma change on about 50% of 45 minutes of the footage. Fortunately I was also shooting with a PMW350 which is clean so I’m OK but I’d like to work out what the issue is here for the future.
    I’m assuming it’s not a hardware fault but can’t work out what else it could be. My settings were as follows:
    1920×1080 25P
    Manual exposure 50th/sec shutter f/4
    ISO 160
    sharpness 0
    contrast -4
    saturation 0
    Here’s a link to a short QT movie showing the problem. It’s really obvious if you scroll quickly through the clip: 1341_5dbrightnessflicker.mov.zip
    Any thoughts?
    Chris Wright replied 14 years ago 7 Members · 14 Replies
  • 14 Replies
  • Phil Balsdon
    December 1, 2010 at 8:25 pm
    Sample in link looks stable to me.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://www.steadi-onfilms.com.au/
  • Pete Burger
    December 1, 2010 at 8:54 pm
    I could spot a brightness change on the wall in the back. I would assume it’s the changing brightness from outside the window.
    But that should be on the footage of the PWM as well… So, indeed very strange…
  • Andy Taplin
    December 2, 2010 at 12:27 pm
    It’s definitely not the light changing as it’s only on the 5D footage. You can see the levels change on the whole image, although it’s much more noticeable on the BG.
    I assume in manual mode there are no ‘gotchas’ where there is still some auto exposure compensation going on?
  • Pete Burger
    December 2, 2010 at 12:58 pm
    Did you set the “highlight tone priority” and “auto lightning optimizer” to off? In some cases they produce strange artifacts – at least on my T2i and the 7D.
  • Andy Taplin
    December 2, 2010 at 1:20 pm
    Auto Lighting Optimiser was set to standard, so maybe that was it. I’ll try some tests
    Thanks for the replies
  • Chris Wright
    December 5, 2010 at 11:13 pm
    also, just to see if I could fix your footage, I made a quick auto fix after effects project. it auto fixed your white balance and flickering exposure.
    ae cs3 aep
    https://www.mediafire.com/?snyc3empeaea2bk
    a gui script for enabling expressions(if you scrub, sometimes they get disabled)
    https://www.redefinery.com/ae/view.php?item=rd_ExprTweaker
    https://technicolorsoftware.hostzi.com/
  • Andy Taplin
    December 6, 2010 at 11:17 am
    Thanks Chris that ‘s really good of you 🙂 I’ve tried the AFX effect in the past that’s supposed to even out exposure without much success.
  • David Williamson
    June 10, 2011 at 8:33 am
    Any chance you could re-post that auto-exposure fixing AE project? I’ve run into the same issue with exposure flickering…
  • Chris Wright
    June 10, 2011 at 8:58 pm
    https://www.mediafire.com/?fz0s3i85a45ou58
    from thread
    https://forums.creativecow.net/thread/50/857931#857958
    if you un-hide the final output comp, and enable the top empty text layer, it will show numbers in your comp. If it says around 25 (+-5 deviation) from gamma clamp slider, the flicker will be removed automatically.
    it may need a new keyframe for a new scene to scene change, but for the most part, it’s fully automatic. obviously before you render, turn the text layer off.
    also, if you’re interested, I made a highlight restore program that recovers blown out spots in video >2x adobe’s RAW capability too.
    https://www.mediafire.com/?o5724wvxd07mkv7
    from thread
    https://forums.creativecow.net/thread/2/978546#978880
  • Dean Barker
    November 24, 2011 at 5:35 am
    can you tell me how to apply your auto fix filter? – i’m very green with after effects so explain it like you would to a newbie – thanks!
