Activity Forums Apple Final Cut Pro Legacy Canon 5D video
  • Posted by Christopher Bruno on April 16, 2009 at 7:29 pm
    Ok, So I’ve recently just started working with the new Cannon 5D mark II these past couple months. I must say its amazing. However, I wanted to know if there is an easier way to work with my XH-A1 footage and my 5D together in the same sequence, for they are both at two different compression rates.
    Therefore, I constantly have to render my 5D video. Thus, sometimes leading to a system crash; however, not common, but frequent enough to mess up with work flow.
    Can anyone help or have advice on this?
    Chris
    Chris
    Rafael Amador replied 17 years, 4 months ago 4 Members · 5 Replies
  • Zane Barker
    April 16, 2009 at 8:40 pm
    To my knoledge the 5D saves video as h264 files. H264 is not a good codec to edit with, you should convert the files to a more friendly editing format.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Michael Sacci
    April 16, 2009 at 8:52 pm
    If you are mixing the 5D with other video files, convert them to that same codec.
  • Christopher Bruno
    April 16, 2009 at 9:52 pm
    How would i go about converting my XH shot at 60i to the same codec? I generally just keep the sequence on the codec i use most. However, latley i find myself using 5d more.
    Is there a way to convert the clip itself that i am unaware of?
    Chris
  • Christopher Bruno
    April 16, 2009 at 9:54 pm
    Figures! haha. I didn’t know canon had a PAL version though. Thanks for the info!
    Chris
  • Rafael Amador
    April 19, 2009 at 1:22 pm
    Hi Christopher,
    The Canon 5D records H264.
    What many people are doing is to transcode the files to ProRess, then, as Dave suggested, conform the files with CinemaTools to 23’98.
    I wouldn’t try to conform directly the h264.
    It may work, but I tried with MPEG-2 (EX-1, so .mov) and I couldn’t conform the files.
    rafael
    http://www.nagavideo.com
