Activity Forums Apple Final Cut Pro Canon 5d Strobe Light artifact: how to fix?
  • Canon 5d Strobe Light artifact: how to fix?
    Posted by Cyrus Dowlatshahi on July 21, 2011 at 7:54 pm
    https://vimeo.com/26735099
    password: cow
    Here is a link to some footage I shot at an underground party. I would like to create just a short segment of the dance floor, and I’m looking to stylize it since the strobe lights wreaked havoc on my 5d’s CMOS sensor.
    Any editors out there have any ideas? I’m in FCP X but can work with this segment in any program really.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Craig Seeman replied 15 years, 1 month ago 4 Members · 3 Replies
  • Brian Mulligan
    July 21, 2011 at 8:49 pm
    You can try some sort of frame blending like AVERAGE. it will smeat the images slightly.
    From what I can tell, it’s not on every frame, so maybe you just edit the clean ones together. It will have that studdery feel, but then again, that is what the strobe light gives you.
    You can repeat some of the frames to fill in the gaps between bad frames… might be a cool look.
    Brian Mulligan
    Senior Editor – Autodesk Smoke
    WTHR-TV Indianapolis,IN, USA
    Twitter: @bkmeditor
  • Simon Ubsdell
    July 21, 2011 at 8:52 pm
    [Brian Mulligan] “You can repeat some of the frames to fill in the gaps between bad frames… might be a cool look.”
    Or cut in a frame of white over the top of the offending frames.
    Boy, have you got to love that cool CMOS technology 😉
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
  • Craig Seeman
    July 22, 2011 at 12:42 am
    Maybe use one of the “TV” filters. The scan lines might make the whole thing look like it’s part of the effect.
