Activity › Forums › Apple Final Cut Pro Legacy › Canon 5D Question
Canon 5D Question
Posted by Matthew Rundell on October 23, 2010 at 7:40 pmNew to this workflow. But is the best way to get the original h264 dalies into final cut is through compressor? Using ProRez Hq or other?
Thank you.
Matt Rundell
Jim Edds replied 15 years, 11 months ago 4 Members · 5 Replies -
Zane Barker
October 23, 2010 at 7:45 pmH264 questions like yours get posted daily. Have you searched the forum for the answer?
**Hindsight is always 1080p**
Shane Ross
October 23, 2010 at 9:53 pmThis way…tapeless workflow with FCP, including a link to the Canon EOS plugin to allow the Canon camera to be seen in Log and Transfer.
Tapeless Workflow for FCP 7 Tutorial
Or you can use Magic Bullet Grinder…
Or you can use Compressor…
Shane
Read my blog, Little Frog in High Def -
Jim Edds
October 24, 2010 at 2:54 pmShane:
The Canon EOS Utility has a feature to back up the card as a disk image .dmg file. Ever used this? Any pros/cons to it? My first though is you won’t see the actual files captured.
MBP I7 2.66 8GB RAM, 140GB SSD, FCP 7, OS 10.6.4 ExtremeStorms.com
Shane Ross
October 25, 2010 at 2:00 am[Jim Edds] “The Canon EOS Utility has a feature to back up the card as a disk image .dmg file. Ever used this?”
Nope.
[Jim Edds] ” Any pros/cons to it?”
Well, when you unzip it it will be the full card structure, but it won’t be inside a backup folder, with a unique name you give it that becomes the REEL name, that is VERY helpful for tracking footage.
Shane
Jim Edds
October 25, 2010 at 4:53 amThat’s a very good point. Think I’ll pass on the canon image files for now.
