Activity Forums Avid Media Composer Canon 5D Mark II footage Workflow?
  • Canon 5D Mark II footage Workflow?
    Posted by Warren’s Oates on January 20, 2010 at 4:43 pm
    Does anyone know the best way to import and edit this camera’s HD footage? This camera shoots 1080p at true 30fps in Quicktime H.264 format. I’m running Avid v.3.1.2. In creating a new project, the settings do not offer these exact specs, only 23.976, 24, & 25fps for 1080p. Footage pulled into 23.98 naturally looks stuttery.
    Any insight into this dilemma would be appreciated.
    Giulio Tami replied 14 years, 11 months ago 5 Members · 9 Replies
  • 9 Replies
  • Joe Womble
    January 20, 2010 at 6:02 pm
    Import the .mov files and transcode them to DNxHD. There should be no degredation, and the Avid codec will stand up to layers, effects, playback, etc. much better than other options.
    Regards,
    Joe Womble
  • Warren’s Oates
    January 20, 2010 at 7:49 pm
    Hey Joe
    Thanks for the quick response, but it does not address my frame rate problem. I agree the DNX_HD wrapper works wonders but this footage is 1080p 30fps. Avid doesn’t give you an option to set up a new project as 1080p/30fps, thus the Canon footage is wonky in any other 1080p project.
    Still stumped in stinky town.
  • Bouke Vahl
    January 21, 2010 at 9:06 am
    You have to go into the console, and enter
    IgnoreQTrate = True
    this will force Avid to import a frame as a frame.
    (effectively slowing it down to 29.97)
    Now this works great, but your audio will be out of sync.
    To compensate for that, export the audio as wave files, and set a 48.048 sample rate on it. (there are free tools to do so)
    Another option would be to use my QTchange application.
    This can batch add timecode to the clips, and do a speed change.
    The timecode is nice to have, but won’t come across on your sytem.
    (qt tc on import / export came to MC on version 4)
    Michael Philips got the speed change to work with Avid, but i don’t trust it very well. (and it works destructive)
    So if you do toy with it, work on copies of the original.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Joe Womble
    January 21, 2010 at 2:21 pm
    Sorry I have been out of pocket…
    See Bouke’s post. We just had the same discussion on the Avid-L2 with Bouke and Michael Phillips chiming in, and all agreed that the videotoolshed solutions are tried and true.
    I trust Avid will have its own solution via AMA at some point, but for now, Vahl-hala is only a third-party application away…
    Regards,
    Joe Womble
  • Bouke Vahl
    January 21, 2010 at 2:44 pm
    CORRECTION.
    The Canon records audio at 44.1,
    So first upsample to 48K, THEN change the SR to 48048
    Bouke
  • Warren’s Oates
    January 21, 2010 at 3:06 pm
    Hey Guys
    Thank you so much for the detailed response. I can’t wait to try these solutions. This is why I love the Cow.
    Much appreciated!!!!
  • Warren’s Oates
    January 21, 2010 at 3:50 pm
    Hey Bouke
    Where do I access console to enter IgnoreQTrate = True ?
  • Michael Hancock
    January 21, 2010 at 4:08 pm
    Hit Ctrl+6 on a PC or Cmd+6 on a Mac and it will open the console. Type it in the little box at the bottom and hit Enter.
    Michael Hancock
    http://www.oswaldcommunications.com
  • Giulio Tami
    October 8, 2011 at 12:02 am
    Hello there.
    This is Giulio from italy, sitting in front of Avid MC 3.0.5 (no AMA).
    Importing a native h264 CanonMarkII file.
    Importing it both in 1:1 and/or 1:1x codec.
    Importing it both in RGB and/or RGB “dither colors”.
    Immediately re-exporting the file from source into either 1:1 or 1:1x or uncompressed or no-compression(none) mov files.
    The result should be absolutely NO difference between this export and the original file, right?
    lossles in.
    lossless out.
    Truth is that the exported file has noticeable differences:
    1) output file color is poorer… meaning the output file is desaturated. Specially on reds.
    2) the output is slightly darker maybe 4/5% than the original, let’s say…
    3) I can definitely see compression
    Should we consider I did something wrong which is possible even if I’ve been an avid editor for 10 years, now…
    Or should we finally state once and forever that avid 1:1
    IS NOT LOSSLES AT ALL?
    Another consideration:
    Canon MarkII files run around 45 mb/s.
    Importing them into a dnxhd 120 codec should give them range enough (dnxhd120 is 120 mb/s which is almost 3 times what needed to deal the native canon bitrate…)
    But once exported… into uncompressed quicktime… the file is soooo damn shitty compaired to the original.
    Please someone help me
