Activity › Forums › DSLR Video › Canon 5D features
  • Canon 5D features
    Posted by Grzegorz Kwiatkowski on December 14, 2012 at 12:00 am
    I am going to shoot a TV program using two Canons 5D. One is MKII, the second is MKIII. I want to record audio directly into MKIII to save days of syncing time. I want to connect two audio sources: microport and external boom mic.
    – would you rely on recording audio only to MKIII or rather use dual system (recorder + going directly)?
    – do you have any experiences with Juicedlink? What is the audio quality with this hardware?
    – has anyone used dual system (connecting mics with XLRs to the recorder and then through mini-jack output-input to DSLR? what recorder is the best for such solution?
    – does MKIII has any audio limiter (auto mode) to prevent from distortion?
    – can you genlock SMPTE into MKIII for multicam shoot?
    Thanks for answers.
    Mark Shepherd replied 13 years, 9 months ago 5 Members · 10 Replies
  • 10 Replies
  • Sareesh Sudhakaran
    December 14, 2012 at 9:26 am
    I will never recommend recording audio on a DSLR. No genlock. Try Zoom H4N. Get a good sound guy.
    https://www.wolfcrow.com – Workflow information and support for filmmakers, photographers, audiographers and videographers.
  • Grzegorz Kwiatkowski
    December 14, 2012 at 10:43 am
    However Sareesh, have you tested recording on Canon 5D mark III?
  • Al Bergstein
    December 14, 2012 at 2:13 pm
    Dual system is always best, IMHO.
    But,
    Mkiii does have agc limiter, but i have not used it for pro work. Not true limiter. Unless i’ve missed something.
    Mkiii has timecode but i don’t believe it is in. Check the online manuals. My guess is out only. Does do rec run.
    I have done dual systems with a SD mixpre. Works fine. Practice first.
    No experience with juicelink.
    A sample of audio directly into the mkiii using a wired lav is here. No audio sweetening. Quick and dirty.
    https://vimeo.com/53916496
    Al
    December 14, 2012 at 3:37 pm
    No, Grzegorz. Check out my post on the subject: https://wolfcrow.com/blog/comprehensive-guide-to-rigging-any-camera-13-audio-part-1/
    Hope this helps.
  • Mark Shepherd
    December 16, 2012 at 6:06 pm
    I have used the Mark111 with both wireless and hard wired mics going DIRECTLY into the camera. The sound is fine for most situations, interviews. If I record in a situation where the sound is very loud (music) I would use a mixer with a good limiter to feed it into the camera or record double system. If the sound levels are not all over the place feeding a mic DIRECTLY into the Mark111 works perfectly. I also have bought a 3.5 mini plug (stereo) that splits the cable into (2) XLR inputs so you can use a boom mic with a lav, or two lavs. The only big problem with using a boom mic, in my case my Sennheiser 415 is that it has to be phantom powered which requires a mixer or a 48 volt phantom device. If you are just doing an interview with the Mark111 you can be a one man band and wear headphones coming out of the Mrk111 to check quality, but if you are using a boom and a lav you will need a sound man but you don’t need to go double system.
    December 17, 2012 at 7:10 am
    Thanks for the link Al. The voice is warm and nice but the hum pretty apparent. Why is it so?
  • Mark Shepherd
    December 17, 2012 at 2:57 pm
    The “hum” that you hear is probably from the all the water pumps that are just behind the subject. You can see one clearly by his right arm.
  • Al Bergstein
    December 17, 2012 at 4:05 pm
    Right you are. It’s an industrial facility, so there were background noises. Especially pumps. That’s why close mic’ed.
    Al
  • Brent Dunn
    December 20, 2012 at 6:03 pm
    Yes, you could go direct, but if you have an external recorder, you should record to both for backup. If you use Plural Eyes, it should synch.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro
    with Final Cut Studio Adobe CS6 Production
  • Mark Shepherd
    December 21, 2012 at 1:51 am
    My question wasn’t “can I go direct to an external recorder?” I want to know if the QUALITY of the recording would visually better, IE: more resolution and detail and information. I know that recording 4:2:2 in ProRes would be better for green screen, but that is not why I would want to record to an external recorder with a codex other than H264. My original post was asking the question about WHY the Canon 5DMark11 video looks worse that SOny XDcam.
