Activity Forums Avid Media Composer Canon 5D Audio Sync Multicam on MC5
  • Canon 5D Audio Sync Multicam on MC5
    Posted by Franco Bogino on January 19, 2011 at 1:29 pm
    Hi
    I would like to know if it is possible to sync outboard audio to 5D footage using the multiclip function. I have tried but the stereo channel from the 5D remains in the clip, replacing the Channel 1 & 2 from the outboard audio (only channels 3 upwards remain in the multiclip).
    I’d like to be able to create self contained clips because the method of syncing on a sequence becomes a pain when editing, especially later on in the edit when I need to match frame back to original clips.
    Any thoughts? I’m on Media Composer 5 at the moment, but I expect it will be the same for previous versions.
    While I’m on the subject of working with sequences as clips, has anyone found a way to combine several tapeless clips into one large clip by any other means than using a sequence as a ‘virtual’ clip? And I’m not talking about creating mixdowns or anything like that…more like some kind of multiclip feature where the clips are grouped end to end.
    Cheers
    Franco
    Franco Bogino replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
