Activity › Forums › Apple Final Cut Pro Legacy › Canon 5D
Canon 5D
Posted by Tom Fraser on July 28, 2010 at 10:23 pmI am shooting test with the 5D
Using onboard sound
Input via log and transfer ( Pro Res 422 HQ)
Place on timeline (FCP HD)
Audio is 2 frames out of sync?????
Alan Thorburn replied 16 years, 1 month ago 4 Members · 8 Replies -
Steve Eisen
July 28, 2010 at 11:23 pmYour frame rate is?
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group -
Alan Thorburn
July 29, 2010 at 5:55 pmI have this same camera and FCP setup.
Make sure you are monitoring your sound via the HDMI output and not through the Apple computer’s sound card. That would create a 2F offset . . . cause it does on mine.
Tom Fraser
July 29, 2010 at 6:08 pmthe picture and sound track are aligned out of sync by two frames on the timeline
Alan Thorburn
July 29, 2010 at 10:05 pmI’ve heard you don’t need to use Apple Pro Res HQ, just the regular Apple Pro Res will do. Try doing a test file and see if that helps. Also, try to use your desktop display and run the audio through the Apple sound card and see if that helps.
