Activity Forums Adobe Premiere Pro Canon 550D video editing settings?
  • Canon 550D video editing settings?
    Posted by Elliot Beach on June 7, 2010 at 6:55 pm
    I need to edit some video for a short music video and want to get the correct sequence settings for editing the video in Adobe Production Premier.
    The 550D shots in full HD 1920×1080
    I’ve tested a couple out and I seem to get the best results with (if shooting in 30fps):
    – DVCPROHD 1080i60, 29.97 fps, Progressive scan, Frame size locked at 1280×1080 (16:9)
    If shooting at 24fps would I just change the fps in the sequence settings to 23.976?
    Are these the right settings for 30fps?
    Is it better to shot in 24fps or 30fps?
    What other tips/advice can you give for getting the best quality video and editing set up for the 550D?
    Thanks, E =)
    Tim Kolb replied 16 years, 3 months ago 3 Members · 2 Replies
  • Vince Becquiot
    June 7, 2010 at 9:50 pm
    The camera records H.264, which is a square pixel PAR.
    DVCPro is not, so you are adding the burden of PAR conversion on top of the processing (unless you are remdering).
    I usually just use the desktop sequence setting, 1920×1080 square (1.0).
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Tim Kolb
    June 9, 2010 at 1:10 am
    CS5 will take the footage in it’s native form…runs like a bandit on a decent system.
    TimK,
    Director, Consultant
    Kolb Productions,
